Starter Removal Help |
vesnyder |
Sep 24 2006, 06:27 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I need to replace my starter and removing the bolt on top looks impossible without removing the engine - what is teh secret or do I need to remove the motor? Access looks tough, but coming at it from the other side of the car and it does not even look like I can get a wrench on the bolt or even turn it if I could - HELP?
Mueller |
Sep 24 2006, 06:31 PM
it is a NUT on the engine side that you remove......
either 15mm or 17mm |
Dr. Roger |
Sep 24 2006, 06:51 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
i use 2 or 3 socket extensions and that brings my ratchet out behind the transaxle. no problem.
a wobble extension makes it even easier. good luck. |
ConeDodger |
Sep 24 2006, 07:09 PM
Apex killer! Group: Members Posts: 23,607 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I just want to say thanks to Mike and Roger. So many times when I see someone ask a simple question like this I see an answer or two to the effect - check the archives or ha ha you're stupid. Very cool that you respectfully answered.
Maybe all the A-holes are at some event? Nah... JK! I'm not jelous no... really. (IMG:style_emoticons/default/biggrin.gif) |
turboman808 |
Sep 24 2006, 09:27 PM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
I took one out on a 4 but for some reason I just can't see it on my 6. I have to get it on a lift and use the long extension.
I could probably do it in the driveway but Ray has given us wonderful use of a lift and I hate to be on my back so I will wait til I get it one the lift. |
ConeDodger |
Sep 24 2006, 09:39 PM
I took one out on a 4 but for some reason I just can't see it on my 6. I have to get it on a lift and use the long extension. I could probably do it in the driveway but Ray has given us wonderful use of a lift and I hate to be on my back so I will wait til I get it one the lift. On the six it is in the same spot. I have had a spat of starter problems lately so I have become quite aware of the locations and what not... On my six it is in the same spot, it is the same starter in fact. However, on the six, I do not recall having to go up into the engine compartment and go after a nut. I may be wrong, but I think I just turned both the upper and lower bolt off from underneath... |
Mueller |
Sep 24 2006, 11:26 PM
i use 2 or 3 socket extensions and that brings my ratchet out behind the transaxle. no problem. a wobble extension makes it even easier. good luck. Rogers advices really does not help "that" much...his car is a V8 conversion which places all the hardware on the transmission side...nothing in the engine bay starter related (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 11:47 AM |
