Blinker problem |
Blinker problem |
vertigo |
Sep 27 2006, 09:02 PM
Member Group: Members Posts: 72 Joined: 12-June 05 From: Porterville, Ca Member No.: 4,262 |
'73 2.0 /recently when I turn blinker (to right) and press brake the blinker on dash dims and both flash. Release pressure on brake and it blinks normally. This only happens with right signal and not left. Has anyone experienced this before and if so what might be the fix? Thank you in advance.
So.Cal.914 |
Sep 27 2006, 10:06 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Yes I have, quite often it is the ground but not in my case. I pulled down the fuse
panel and drew a diagram of the back and assigned a number to every paddle connector. I than used stick on numbers that we used to use for wireing elect. panels(you can get them at any elect. parts house) they come on a drum dispenser and put them on the wire that came off the paddle with the same number. Pull all the fuses and than clean all the brass connectors front and rear with a good metal cleaner made for silver, copper, or brass. these cleaners are more mild and will not damage the metal. Than put it back together. Every- thing worked great. My .02 |
Spoke |
Sep 27 2006, 10:48 PM
Jerry Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
When you say "both flash", do you mean both turnsignal lamps on the dash or both outside blinkers and brake lights?
Have you changed any lightbulbs or other electrical items lately? Maybe check the rear taillight assembly for good grounds. Maybe take out the lamps and check for good connections with a multimeter. Spoke |
vertigo |
Sep 28 2006, 08:35 AM
Sorry, yes both lights on cluster flash. The blinkers on outside remain correct. About 3 month ago I did change the return cog for the blinker, but it has worked fine until 3 days ago.
HCRDAN |
Oct 7 2006, 09:57 PM
Member Group: Members Posts: 113 Joined: 24-September 06 From: Austin, TX Member No.: 6,907 Region Association: None |
Sorry, yes both lights on cluster flash. The blinkers on outside remain correct. About 3 month ago I did change the return cog for the blinker, but it has worked fine until 3 days ago. I had similar problem. Replaced a flasher bulb (right front) maiking sure I had correct 2 filament bulb and that started a cascade of issues. Cleaning contacts on bulb socket helped keep fuse from blowing, but after that, both lights would flash on tach, while outside lights would flash correctly. Replaced flasher relay and that seems to have solved the problem |
Lo-Fi Version | Time is now: 11th June 2024 - 10:17 AM |
