Need carb advice quick... |
rtalich |
Sep 28 2006, 03:14 PM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
I'm just about to purchase the 40mm Webers that are listed in the FS section. They are off of VW. The add says they were installed on a VW. Besides the intake being different, are they virtually the same carb you can buy for the 914? Any differences I need to know about?
Also, will the intakes that just went for sale bolt on? Thanks, Rob |
rtalich |
Sep 28 2006, 03:15 PM
bump
Thack |
Sep 28 2006, 06:43 PM
Member Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 |
What year is your car? What size engine? What size engine did the carbs come from?
rtalich |
Sep 28 2006, 07:18 PM
Its a '74 2.0L...
Matt Romanowski |
Sep 28 2006, 07:21 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
Didn't see the ad, but all IDF's are basically the same. They've changed were they make them, but the basic carb is the same.
Matt |
Thack |
Sep 28 2006, 07:40 PM
Rob, I don't think you could go wrong with your idea to get the carbs and the intakes listed separately. The number of holes on the intakes vary between the year model I think. I'm not sure of your car's intake config but I'm sure a drill press can remedy any problem. You would stilll need the linkage between the carbs. It's a long aluminum bar with adjustable fittings on the ends. Easy enough to find here or on ebay.
McMark |
Sep 28 2006, 07:51 PM
The carbs will be fine, it's the manifolds that might not work. But manifolds are cheap.
Thack |
Sep 28 2006, 08:15 PM
This cross bar could work. I see the linkage with heim joints are attached to the carb in the FS section.
http://cgi.ebay.com/ebaymotors/VW-BUGPACK-...1QQcmdZViewItem and these intakes would definitely work. http://cgi.ebay.com/ebaymotors/VW-WEBER-ID...1QQcmdZViewItem |
Joe Ricard |
Sep 28 2006, 10:33 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
CB performance makes an OK linkage.
I have no idea who made my linkage butit mounts to the case and pivots there with reach rodsgoing ot to the carbs. Very little slop. I need to have a machinist make me a couple more. |
So.Cal.914 |
Sep 28 2006, 10:50 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
The manifolds will work with your 2.0 L and the carbs.
Bleyseng |
Sep 29 2006, 08:51 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
If you are looking to ditch the FI for carbs, why? I saw your car this week and I thought it was running good?
Carbs work only if you switch out the cam to a carb cam otherwise stay with the FI as its more hp/torque than if you switch to carbs. |
rhodyguy |
Sep 29 2006, 09:10 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
how the carbs are configured is crucial. venturi size, newmerous #s for jetting. if you have to start guessing, buying, changing items, buying a syncronometer (you WILL need one), a good low pressure rotary fuel pump, a manual to help you thru the install, assorted fuel lines, some sort of breather box setup/case venting, potential rebuilds(they are used)... you'll get frustrated in a hurry. first time out of the blocks dialing in the carbs is quite the adventure. if your djet works well, save the money. ps, the cb setup does not include a throttle cable holder. be prepared to fab something up.
k |
rtalich |
Sep 29 2006, 11:13 AM
If you are looking to ditch the FI for carbs, why? I saw your car this week and I thought it was running good? Carbs work only if you switch out the cam to a carb cam otherwise stay with the FI as its more hp/torque than if you switch to carbs. I'm keeping my setup as is for now... Eventually I'd like to put the carbs on or maybe start build a new motor. |
Bleyseng |
Sep 29 2006, 02:25 PM
If you are looking to ditch the FI for carbs, why? I saw your car this week and I thought it was running good? Carbs work only if you switch out the cam to a carb cam otherwise stay with the FI as its more hp/torque than if you switch to carbs. I'm keeping my setup as is for now... Eventually I'd like to put the carbs on or maybe start build a new motor. for a new motor I'd suggest either a McMark 2056cc 125hp drop in or a Jake engine kit -2056 or 2270. http://www.914world.com/bbs2/index.php?showtopic=42456 http://www.type4store.com For resale, stock cars lose about $500-1000 off their value if they don't have FI. Put it in a box when you switch. |
Lo-Fi Version | Time is now: 7th June 2024 - 09:59 AM |
