Plug Wire Choice with MSD & Pertronix, Beru Connectors okay? |
Allan |
Sep 28 2006, 06:51 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I have neen running these skinny 7mm plug wires with the new MSD 6AL, Blaster II coil and Pertronix for both street driving and at the track. They seem to be doing pretty well.
My question is, MSD says that I need suppresion wires for the MSD and coil to work at it's optimum efficiency. The fat wires I bought have Beru connectors on them. Is this okay? I have heard (through other boards) that the Beru type connectors do not work well with the MSD. A. True B. False. Thanks... |
bd1308 |
Sep 28 2006, 06:56 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
if they work, why change it?
Series9 |
Sep 28 2006, 07:15 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
Use very low resistence wires with the MSD. Liz and I spent a month pulling our hair out over the quick expiration of every cap/rotor we intalled.
Turned out to be the Magnecore resistor wires we were using. Going back to stock wires solved the problem. |
ThinAir |
Sep 29 2006, 12:32 AM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
I'm running a Pertronix with a Bosch Blue Coil and the Magnecor wires from Pelican Parts do just fine with that setup.
shaggy |
Sep 29 2006, 12:36 AM
mechanic/welder/fabricator Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
ive used pertrinics with bosch blue coil and bosch premium 7mm wires with no problem.
-shag |
Joe Ricard |
Sep 29 2006, 05:22 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
personally can't stand Beru type connectors. I usually end up burning the connections where the wire and connector screw together.
I have not hada lick of problems with my 7mm Magnacor Electrosports. which are suppression wires for the Hyfire box. |
Root_Werks |
Sep 29 2006, 07:48 AM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Allan, A 914-6 recently was running MSD/Pertronix and matching blaster2 coil. Kept frying the cap/rotor and even the tip of the coil. Just as series9 said, moving back to stock wires fixed the problem. The MSD system requires a certain amount of resistance to work with other items correctly.
I think, but am not sure that means spark plugs as well. But I am not sure. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 10:47 PM |
