MarkeyDoo and RRC Pipples, ...engine lock question. |
Eric_Shea |
Oct 4 2006, 11:17 AM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I seem to remember the issue where your engine was locked. What caused that? Anyone?
Aaron Cox |
Oct 4 2006, 11:19 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
hydrolocked....
car at an angle.... on tow dolly... filled cylinder with fuel.....drained bowls of carbueretors.. (they established that it never went into gear...) put it in a forward gear and rolled it backward a few strokes...... started right up (IMG:style_emoticons/default/smile.gif) |
Eric_Shea |
Oct 4 2006, 11:22 AM
Did he change the oil after that??
Aaron Cox |
Oct 4 2006, 11:25 AM
dunno....
not a TON of fuel in the bowl but you are right.. probably a good idea.... couple ounces in the bowl.... some got past the rings.... some stayed inthe cylinder... then went out the exhaust valve...... hmmm..... few ounces / 9 qts or so of oil - probably not a huge issue.... |
Lo-Fi Version | Time is now: 17th June 2024 - 12:04 PM |
