2.0 73 MPS in a 2.0 74, Will this work? |
Dads914 |
Oct 11 2006, 11:27 AM
Greg Group: Members Posts: 49 Joined: 21-June 06 From: So. Cal. Member No.: 6,277 |
Let me start by saying that I did a search on this topic and could not find the answer.
Will an MPS out of a 73 2.0 p/n 0 280 100 037 be compatible with a 74 2.0 car with a completely stock engine and D-Jet system? Thanks, Greg |
drgchapman |
Oct 11 2006, 11:38 AM
Current Stable Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest |
You need to read Brad Ander's site on D-jet.
http://members.rennlist.com/pbanders/djetfund.htm If I remember right, he thought the 74 MPS was the best one.......or something like that. |
ptravnic |
Oct 11 2006, 11:46 AM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
The 037 MPS will work if you have the 037 ECU & a specific CHT (forget the number on that though...). Brad Anders site gives the low down on compatibility.
-pt |
Dads914 |
Oct 11 2006, 11:54 AM
The 037 MPS will work if you have the 037 ECU & a specific CHT (forget the number on that though...). Brad Anders site gives the low down on compatibility. -pt Thats the first place I went before i posted the topic here. From what I see on that site the 73 may not work in a 74 , But im looking for someone who has tried it in the real world. His site didnt give me a complete clear answer. Greg |
mihai914 |
Oct 11 2006, 03:19 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
It will work (even a 1.7 one will work), but it won't be the best, the car will run too rich or too lean and that's just asking for trouble and performance won't be optimal either. You need the combination of 037 ECU, 037 MPS, 017 CHT and the ballast resistor which people sometimes forget about. It's alot of specific stuff so that's probably why Brad preferred the 74+ 2.0 FI system, less parts and better availability since it was used over 3 years vs. one for the 73.
You have three options: Gather all the 73 specific parts to go with the MPS. Have yours recalibrated by Bleysing to 74 specs. Trade your good one with someone else's good 74. I think the third option is the best. |
wilchek |
Oct 11 2006, 03:46 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
They all work together for the most part just not good. I have a 73 system and it is kind of odd. Take your time and get the correct parts it is worth it in the long run. These devices change thru the range of throttle and are hard to make work if they are not the correct device.
Dads914 |
Oct 11 2006, 05:08 PM
They all work together for the most part just not good. I have a 73 system and it is kind of odd. Take your time and get the correct parts it is worth it in the long run. These devices change thru the range of throttle and are hard to make work if they are not the correct device. Thank you all. I passed on the 73 MPS and am going to wait until I can find a working 74. Thanks again for all your help, Greg |
zen motorcycle |
Oct 11 2006, 08:32 PM
almost not a newbie ( way less than a newbie) Group: Members Posts: 259 Joined: 21-May 06 From: Dallas Member No.: 6,038 Region Association: None |
can you give the info on the 73 MPS???
Always looking for spare parts |
Bleyseng |
Oct 11 2006, 09:01 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
can you give the info on the 73 MPS??? Always looking for spare parts Info? 037 MPS fits a 73 2.0L with the 037 ECU, 017 CHT w/270 ohm resistor... On a 74, it will run fairly rich (blackened spark plugs) (IMG:style_emoticons/default/popcorn[1].gif) |
nbscooters |
Oct 12 2006, 12:15 AM
Member Group: Members Posts: 165 Joined: 29-June 05 Member No.: 4,347 Region Association: None |
You need the correct parts for the car otherwise its going to run like crap. Im trying to tackle my excessive fuel consumption because I bought a complete 2.0 FI top end off ebay for my car and come to find out that guy gave me mismatched d-jet parts that dont work with my car. Again it was my fault for not looking it over before purchasing it.
Lo-Fi Version | Time is now: 3rd June 2024 - 07:49 AM |
