Valve covers |
Valve covers |
PORobinSCHE |
Oct 14 2006, 03:41 PM
Member Group: Members Posts: 421 Joined: 22-July 06 From: Orlando,Fl Member No.: 6,484 |
greetings , is there anyone here using aftermaket valve covers? i would like to get rid of the bailing wire clip type ,something that bolts on securely.
cheers (IMG:style_emoticons/default/beerchug.gif) Robin (IMG:style_emoticons/default/givemebeer.gif) |
Mueller |
Oct 14 2006, 03:44 PM
greetings , is there anyone here using aftermaket valve covers? i would like to get rid of the bailing wire clip type ,something that bolts on securely. cheers (IMG:style_emoticons/default/beerchug.gif) Robin (IMG:style_emoticons/default/givemebeer.gif) so you'd rather have more leaking oil eh??? CB Performance if you think you are "improving" things (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/biggrin.gif) |
URY914 |
Oct 14 2006, 05:30 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,038 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Robin, I have a nice set of bolt ons. See the pic. They're real handy because you don't need to change your oil again. Just add oil.
Attached image(s) |
PORobinSCHE |
Oct 14 2006, 06:39 PM
okay.... (IMG:style_emoticons/default/blink.gif) I get the message ,thru your subtle humor (IMG:style_emoticons/default/laugh.gif) . i'll keep what i have>
BTW Paul when would you like me to come get that right door? robin (IMG:style_emoticons/default/type.gif) |
URY914 |
Oct 14 2006, 09:15 PM
okay.... (IMG:style_emoticons/default/blink.gif) I get the message ,thru your subtle humor (IMG:style_emoticons/default/laugh.gif) . i'll keep what i have> BTW Paul when would you like me to come get that right door? robin (IMG:style_emoticons/default/type.gif) I'm home tomorrow afternoon. |
Air_Cooled_Nut |
Oct 15 2006, 12:35 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
I had bolt-on valve covers for my VW (aluminum and finned). For several years (like, 10 or so). I liked the look and mine never leaked so long as I used new O-rings on the studs every time I put the covers back on (O-ring then hold down nut) and cork valve cover gaskets. But it gets to be a real pain when removing the cover takes longer than the actual valve adjustment! (IMG:style_emoticons/default/mad.gif)
I finally got tired of the wrenching and went back to stock valve covers and bails. Yeah, not as purdy lookin' but much quicker and easier valve adjustments now (IMG:style_emoticons/default/wink.gif) |
Air_Cooled_Nut |
Oct 15 2006, 12:37 PM
Interesting, I see the T4 holes for the studs are offset whereas the T1/T3 are more centered in the vertical axis.
Lo-Fi Version | Time is now: 8th June 2024 - 04:23 AM |
