Fog lights Install, To boldly install, where no one has installed before |
srthompson01 |
Oct 18 2006, 06:08 AM
Newbie Group: Members Posts: 45 Joined: 24-September 06 From: oklahoma Member No.: 6,906 |
My 75 was born fog light free. How difficult ( and expensive ) would it be to install original looking, square, in the bumper fog lamps?
(IMG:style_emoticons/default/driving.gif) |
jd66921 |
Oct 18 2006, 06:50 AM
Member Group: Members Posts: 316 Joined: 9-January 06 From: Texas Member No.: 5,394 |
My 75 was born fog light free. How difficult ( and expensive ) would it be to install original looking, square, in the bumper fog lamps? (IMG:style_emoticons/default/driving.gif) Wiring is easy. All the wires are in place. I found an original foglight switch, but any SPST switch can be used if you don't want it lighted. I don't know much about foglights, but there are slotted brackets in the bumper for any standard foglights. I installed cheapy Harbor freight ones fora test. THey are plastic,andtherefore too flexible to mount rigidly, but they work well otherwise. You can choose your own and I think price is anywhere from $10.00- infinity! Write ifyou need more info!! Jeff |
boxstr |
Oct 18 2006, 08:57 AM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
Only thing on the non fog lite 75-76 bumpers is that there is no tab to mount the bolt to hold the lites in place like there is on the bumpers with foglites already mounted.
CCL |
jd66921 |
Oct 18 2006, 09:11 AM
There is on mine! Maybe it had some????
Jeff |
Brian Mifsud |
Oct 18 2006, 09:20 AM
Mechanical Engineer Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None |
I was eyeballing the replacement headlamps for the late (last) camaro/firebird ("F body"???) at Autozone. They are roughy 1.5"-2" tall and about 6" wide, but you have to raid a junkyard to get the mountbracket/ connector or make your own. They would be more appropriately used as "driving lights" rather than "fog".
william harris |
Oct 18 2006, 02:16 PM
914 Restorer Group: Members Posts: 1,459 Joined: 9-January 04 From: Hamilton, MA Member No.: 1,539 |
Hey, if you need a foglight swith (OEM) I got a couple extra. Came with parts cars. One required for every restoration. (IMG:style_emoticons/default/beerchug.gif)
edrotol |
Oct 19 2006, 05:52 PM
edrotol Group: Members Posts: 190 Joined: 23-April 06 From: Woburn, MA Member No.: 5,910 Region Association: North East States |
My 75 was born fog light free. How difficult ( and expensive ) would it be to install original looking, square, in the bumper fog lamps? (IMG:style_emoticons/default/driving.gif) I have several sets of very very very very clean 75-76 fog lights with bulbs and harnesses if you are interested. If you can remove your bumpers (very easy) see if there are tabs to mount fog lights on the steel part of the bumper. If you do you are lucky. If not you then need to fabricate and weld something to hang the fog lights from that very same steel bumper. Assuming your rubber part of the bumper has no fog light openings, it is very easy to use a sharp razor and juist cut around the inner edges. |
Lo-Fi Version | Time is now: 12th June 2024 - 10:37 PM |
