Whats a good price for a 930 trans with LSD? |
356&914&912E |
Oct 30 2006, 02:02 PM
Newbie Group: Members Posts: 13 Joined: 2-April 04 From: Bishop, CA Member No.: 1,873 |
Case is corroded and input shaft/output flanges are rusty.
Reportedly from a 79 Turbo. Thanks Ron |
Air_Cooled_Nut |
Oct 30 2006, 04:18 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
Damn, I thought you were asking about "the" car, not the drive train (IMG:style_emoticons/default/sad.gif) I love those cars! You say "Porsche" and that's the car I think of (IMG:style_emoticons/default/smile.gif)
Brad Roberts |
Oct 30 2006, 04:49 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Right around $1800. The diff used is 1k-1.2k.
Short or long bellhousing and have you checked to see if it is truly a LSD box? It will have a tag on the top of the bellhousing if the factory installed it. A simple white sticker with black type.. says "limited slip" in German.. something like "Spiff" or something.. B |
Dr Evil |
Oct 30 2006, 04:53 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Hey Ron,
Post pics so folks can see the rusty input shaft. |
LvSteveH |
Oct 30 2006, 05:12 PM
I put the Poor in Porsche Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
It think Brad is about right. Prices have been climbing a bit and a nice clean used box is going for around $2200, so $1800 seems about right if it has some cosmetic issues.
propricer |
Oct 30 2006, 06:18 PM
Member Group: Members Posts: 365 Joined: 16-April 04 From: Morgan Hill, CA Member No.: 1,938 |
If a corroded, rusty box is worth $1,800 and a good, clean box is worth $ 2,200, does that mean that a 930 could be rebuilt for $ 400 ... what about synchros at $60 and labor at $150/Hr.
I always figured that rebuilding a 930 would run about $ 2,000. Where can I get it done for $ 400 ??? |
LvSteveH |
Oct 30 2006, 07:26 PM
If a corroded, rusty box is worth $1,800 and a good, clean box is worth $ 2,200, does that mean that a 930 could be rebuilt for $ 400 ... what about synchros at $60 and labor at $150/Hr. I always figured that rebuilding a 930 would run about $ 2,000. Where can I get it done for $ 400 ??? Please tell me where I implied that $2200 was a rebuilt box?? (IMG:style_emoticons/default/wacko.gif) I said "nice clean USED box", a rebuilt 930 is around $4500 +/- If the trans in question only has cosmetic issues, per my post, then $1800 sounds about right to me. I only have about 20 porsche transaxles sitting around, so take it for what it's worth. There's nothing wrong with a smart ass post once in a while, but it helps if you are right in the first place (IMG:style_emoticons/default/thumb3d.gif) |
Dr Evil |
Oct 30 2006, 07:44 PM
If a corroded, rusty box is worth $1,800 and a good, clean box is worth $ 2,200, does that mean that a 930 could be rebuilt for $ 400 ... what about synchros at $60 and labor at $150/Hr. I always figured that rebuilding a 930 would run about $ 2,000. Where can I get it done for $ 400 ??? I'll rebuild it for less than $150/hr (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/idea.gif) Steve, you ahve a tranny hoard over there? If you like selling parts and cores I can get them from you when my customers request such things. Just a thought. |
propricer |
Oct 30 2006, 08:37 PM
Guess I didn't appreciate the sensitivities - I apologize.
Brad Roberts |
Oct 30 2006, 08:44 PM
Every 930 box I have cracked into 1-2 a year since 96 or so has needed second gear synchro's. The owners must thought they had a Muncie 4 speed rock crusher or something? I didnt get it..
I found most of my 930's at Porsche shops who had done 915 conversions in the turbo cars back in the late 80's/early 90's. They are pretty much bullet proof. The stock 76-77 short tranny has an issue with spider gears breaking in the open diffs.. but Porsche changed that for the long bellhousing 78-86 tranny's B |
Dr Evil |
Oct 30 2006, 10:32 PM
Here is a pic of the tranny in question. Supposedly a, "1979 Euro spec LSD 930 trans." How is this verified externally? I know of no way unless I can lay my hands upon it (IMG:style_emoticons/default/confused24.gif)
Does this change any opinions? Attached image(s) |
billd |
Oct 30 2006, 11:13 PM
Member Group: Members Posts: 327 Joined: 25-May 05 From: Palo Alto, CA Member No.: 4,145 |
Here is a pic of the tranny in question. Supposedly a, "1979 Euro spec LSD 930 trans." How is this verified externally? I know of no way unless I can lay my hands upon it (IMG:style_emoticons/default/confused24.gif) Does this change any opinions? The quick way to tell if it is an LSD is to turn the output shaft on one side and watch the shaft on the other side. If the other shaft turns the same way its LSD. If it turns the other way its not. Are you planning to convert this to side shift? If so, how? |
Dr Evil |
Oct 30 2006, 11:21 PM
Nope, will likely be cable (I just so happen to be working on designs for such an aparatus (IMG:style_emoticons/default/idea.gif) ). I knew the whole output shaft bit, I just cant tell by looks (IMG:style_emoticons/default/wink.gif)
billd |
Oct 30 2006, 11:24 PM
Nope, will likely be cable (I just so happen to be working on designs for such an aparatus (IMG:style_emoticons/default/idea.gif) ). \ Is your cable linkage available? If so, what is it likely to run? I assume it will work on a 915 as well as a 930. |
Dr Evil |
Oct 31 2006, 12:41 AM
Right now my design is largely on paper. I need a 915 to get measurements and mock up, oh, and free time from school so the lead time is not looking short. If I could get a free week nthe garage with a 915 I could get one done probably. So far I have a set up for a 901 side shifter that will be bitchen once I finish fabrication, and am awaiting a tail shift nose cone to mock up a tail shifter one. Its all top secret for now (IMG:style_emoticons/default/ph34r.gif)
Target price is $500 or less, but that is in the air as I experiment with other shifters and see how easy they are to get and modify. |
LvSteveH |
Oct 31 2006, 01:00 AM
That trans looks just fine, it's probably been out of a car for a long time, hence the surface rust... nothing a bead blaster can't knock off in a few minutes. It doesn't take much humidity to cause that. Fortunately most porsche transaxles have years of oil and grease to protect them.
I have a pretty good parts hoard, but I'm not very good at letting things go. I'll let you know if I make any progress with "Parts Whores Anonymous". Aaron had to go cold turkey with the club as part of his treatment plan. |
356&914&912E |
Oct 31 2006, 02:28 PM
Dr. Evil
Thanks for posting the picture. From the feedback it sounds like he's asking too much. Ron |
Dr Evil |
Oct 31 2006, 02:34 PM
No worries, Ron. There are others out there, and for less it would appear.
Brad Roberts |
Oct 31 2006, 04:59 PM
How much was he asking?
Most of the Euro tranny's have an external cooler on them. Not sure if this is true for the 930 box, but the 915 Euro boxes have external coolers. Mike, I have two words for you in your quest for cable..(counter weights) This is how Porsche gets the *feel* correct for their cable shifted cars. They use counterwieghts on the end of the levers. B |
JPB |
Oct 31 2006, 05:15 PM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
My word is .005 tolerance and no slop. I have one myself in the making (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 11th June 2024 - 08:01 AM |
