Good 914/VW Wrench in NE Ohio ..., looking primarily for engine tune-up, etc |
vesnyder |
Nov 2 2006, 07:16 AM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
Anybody know of a reasonable priced good mechanic in the Cleveland/NE Ohio area who has experience with 914's and/or VW's? I've done just about everything myself but have some issues such as terrible gas milage and I susoect my timing should be set, and other ignition things that a back yard nechanic cannot do? I've used Autobahn Extremist for my 911 work and have been very happ, but do not feel he has the 914/VW expertise? HELP?
bd1308 |
Nov 2 2006, 08:56 AM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
If you need help getting things right, timing isnt anything terribly special, I have a digital timing light ($200) that I use to time cars to one tenth of a degree. I've also rebuilt several distributors for people here on the club. D-Jet is very simple in operation but things such as a vacuum leak will cause rich running, which will in turn affect your mixture. Other things, such as a bad manifold pressure sensor will cause this as well.
As far as recommendations, I have none, But If i can help out in any way, I'd love to. I've learned alot from these cars over the past year trying to retrofit a 2.0 bus FI system onto my 1.7 engine. The results have been fabulous. Quick starting, rock stable idle and cool running. I dirve my 914 every day, so it really gets a work-out sometimes. |
BarberDave |
Nov 2 2006, 02:08 PM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
If you want to drive to Finley Ohio, try Tab Tanner,Autobon Garage , 1- 419-957-7210 best I have run into .He has my 914 running like it is supose to!!!! Tell him I referred you to him. Dave kimple (IMG:style_emoticons/default/slap.gif) |
tdgray |
Nov 2 2006, 02:29 PM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Vance... you are like 45 - 50 minutes away from me.
I can time your car... done it like 4 times to mine. I may be able to help with your other issues as well... don't know still have some of my own to deal with (IMG:style_emoticons/default/sad.gif) Oh and the best thing... my garage is heated (IMG:style_emoticons/default/biggrin.gif) You bring the suds and parts and I'll help you do the work. |
Lo-Fi Version | Time is now: 15th June 2024 - 01:08 PM |
