What type of hose is this?, vacuum or oil or ??? |
biosurfer1 |
Nov 4 2006, 03:48 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
So on a typical "while i was in there" move, i noticed that more of my hoses were in dire need of changing and i cant figure out from the diagram what type of hose this is, i believe it's oil but i want to be sure, the hose connection is pictured and arrowed. i also attached a wider view so you can see where its located on the engine.
also, if you look close, the connector is not perfectly round anymore, seems to have gotten bent, any ideas on how to round it out again? its only bent near the tip so i dont think it will effect the seal around the bottom. thanks everyone! |
biosurfer1 |
duh, forgot to add i have a 72 1.7
Aaron Cox |
Nov 4 2006, 03:55 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
head breather...
JoeSharp |
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Breather hose for the head, the pipe is perty soft and will bend right back, on a D-Jet they go the the flash back valve. There on both sides.
See my blog :PERMAGRIN: Joe |
biosurfer1 |
Nov 4 2006, 03:57 PM
thanks guys...one more question, it looks like the same size and the oil filter hoses, 13mm, is that correct?
Cap'n Krusty |
Nov 4 2006, 04:16 PM
biosurfer1 |
Nov 4 2006, 05:41 PM
thanks for the replies...all of the hoses are now replaced, and while i do hear a bit of a difference, its not much, but at least i know all the hoses are fresh and dont have to wrry about them for a while now...
now on to figure out why it leaks oil and what the fu@#ing rattles are!!! |
Bleyseng |
Nov 4 2006, 05:51 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
As the Cap't said it goes to the flashback valve and then the 12mm hose goes to the air cleaner to suck the vapor outta the heads.
Attached image(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 08:17 AM |
