So on a typical "while i was in there" move, i noticed that more of my hoses were in dire need of changing and i cant figure out from the diagram what type of hose this is, i believe it's oil but i want to be sure, the hose connection is pictured and arrowed. i also attached a wider view so you can see where its located on the engine.
also, if you look close, the connector is not perfectly round anymore, seems to have gotten bent, any ideas on how to round it out again? its only bent near the tip so i dont think it will effect the seal around the bottom.
thanks everyone!
