New to this forum, 1.8 L to 2.0 |
mfiorito |
Nov 9 2006, 07:31 PM
Newbie Group: Members Posts: 5 Joined: 5-June 06 From: Northeast Member No.: 6,154 |
I am in process of purchasing my 5th 914. I have not owned one for @ 10 years and miss it vary much. Can anyone tell me what the differance between a 1.8L and a 2.0. What is required to make the 1.8 into a 2.0 All the cars I have owned were 1.7s or 1.8s My first one was a 1971 my dad purchased in 1972 and sold it 17 years ago with 40 k on it. My second car was a 1973 and I drove it into the ground fallowed by a 1974 then a 1975 . I sold the last two when I got married. Big mastake getting married and selling my cars.
JoeSharp |
Nov 9 2006, 07:40 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
anthony |
Nov 9 2006, 07:58 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
A 2L engine = 71mm stroke, 94mm cylinders, and 2L heads
A 1.8L engine = 66mm stroke, 93mm cylinder, and 1.8L heads You can add a 2L crank, pistons, and cylinders to make a 1.8 into a 2.0. At that point you might as well consider 96mm cylinders and maybe even more stroke. I agree with Joe. Buy a 2L car if that is what you want. Building engines isn't cheap. |
G e o r g e |
Nov 9 2006, 08:02 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
Can anyone tell me what the difference between a 1.8L and a 2.0. A little less than 200 cc's (IMG:style_emoticons/default/biggrin.gif) crank 66 vs. 71 rods length pistons and cylinders 93 vs. 94 heads spark plug location size 15-20 hp give or take What is required to make the 1.8 into a 2.0 new crank, rods, pistons, cylinders, heads, tin, possibly heat exchangers, efi if you want djet with the 2 ltr. maybe more maybe less (IMG:style_emoticons/default/beerchug.gif) |
So.Cal.914 |
Nov 9 2006, 10:15 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
You can make your 1.8 L a 2.0 L (1971cc) by changing the crank, rods, and P&C's
you can run your heads and the rest. Although the 2.0 heads are a better design and will give you a little more power. |
Cruzing |
Nov 9 2006, 10:43 PM
Member Group: Members Posts: 214 Joined: 23-October 06 From: San Diego Member No.: 7,082 |
You can make your 1.8 L a 2.0 L (1971cc) by changing the crank, rods, and P&C's you can run your heads and the rest. Although the 2.0 heads are a better design and will give you a little more power. He has a good idea, stay away from dealing with rebuilding 2.0 heads, they are a discontinued rebuild only availabilty now,, a pain.. |
G e o r g e |
Nov 9 2006, 11:34 PM
stay away from dealing with rebuilding 2.0 heads, they are a discontinued rebuild only availabilty now,, a pain.. you keep saying that 2 ltr heads are NLA and a pain to rebuild, here are bare NOS at pelican here are new casting CNC to 2 ltr spec and I'm pretty sure Len at HAM, and Adrian and Headflow masters would say that rebuilding stock heads is work, but not the end of the world. |
Cruzing |
Nov 10 2006, 12:03 AM
stay away from dealing with rebuilding 2.0 heads, they are a discontinued rebuild only availabilty now,, a pain.. you keep saying that 2 ltr heads are NLA and a pain to rebuild, here are bare NOS at pelican here are new casting CNC to 2 ltr spec and I'm pretty sure Len at HAM, and Adrian and Headflow masters would say that I am not trying to trump your opinion,,, I am just referring to my own experiance of replacing 4 heads that failed on the EXH side valve seats, valve seats slapping around is a very bad and expensive ordeal, fouling the top of pistons is no fun either, finding the good machine shop and having enough money here in S.D. there are none up to the task ($1,300-$2,100 per set min as per your link, well that is not cheap either) I gave up and went with a 6cyl to get out of the cycle.. That is all I am referring too as just a warning of what could happen... (IMG:style_emoticons/default/smile.gif) |
rick 918-S |
Nov 10 2006, 12:28 AM
Hey nice rack! -Celette Group: Members Posts: 20,493 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
G e o r g e |
Nov 10 2006, 12:31 AM
I am not trying to trump your opinion,,, I am just referring to my own experiance of replacing 4 heads that failed on the EXH side valve seats, valve seats slapping around is a very bad and expensive ordeal, fouling the top of pistons is no fun either, finding the good machine shop and having enough money here in S.D. there are none up to the task ($1,300-$2,100 per set min as per your link, well that is not cheap either) I gave up and went with a 6cyl to get out of the cycle.. That is all I am referring too as just a warning of what could happen... (IMG:style_emoticons/default/smile.gif) buying replacements of most items on these cars of ours is not cheap. but rebuilding heads from len was running 600 this week + parts. most of the opinions i have read on here about head work state that you need to have a shop that has a clue as to the type 4 heads before you allow them to do anything. |
Mueller |
Nov 10 2006, 01:16 PM
I am not trying to trump your opinion,,, I am just referring to my own experiance of replacing 4 heads that failed on the EXH side valve seats, valve seats slapping around is a very bad and expensive ordeal, fouling the top of pistons is no fun either, finding the good machine shop and having enough money here in S.D. there are none up to the task ($1,300-$2,100 per set min as per your link, well that is not cheap either) I gave up and went with a 6cyl to get out of the cycle.. That is all I am referring too as just a warning of what could happen... (IMG:style_emoticons/default/smile.gif) oh great, a Grant/Trekkor groupie.... (IMG:style_emoticons/default/biggrin.gif) another option is to keep all the 1.8 internals and 1.8 heads and use larger pistons and cylinders, the "norm" big bore kit yeilds a 1911cc...this will be a short stroke motor, it gives up a little bit of torque compared to a "real" 2.0, but it is still a very enjoyable engine... |
Lo-Fi Version | Time is now: 10th June 2024 - 10:29 PM |
