New fuel line, for carbs |
SGB |
Nov 12 2006, 07:29 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
I think I'm gonna be replacing the original fuel lines.
Question: Do most folks replace through the center tunnel? I saw that Chris has SS replacements for the tunnel, but I want to run under the rocker panel on the drivers side. Is this "acceptable". Any reason I should not do it this way? What about the route? I could run up and through the existing vapor return line holes, then down inside the front fender and through the existing holes in the bracket things to get back to the engine zone. Is this going to be OK or does the high point creat a problem? I think it would sorta be a "trap" like a sink drain, but the fuel is under pressure when the key and pump are on. Opinions? Experiences? Comical assides? Attached thumbnail(s) Attached image(s) |
0396 |
Nov 12 2006, 07:46 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
I think I'm gonna be replacing the original fuel lines. Question: Do most folks replace through the center tunnel? I saw that Chris has SS replacements for the tunnel, but I want to run under the rocker panel on the drivers side. Is this "acceptable". Any reason I should not do it this way? What about the route? I could run up and through the existing vapor return line holes, then down inside the front fender and through the existing holes in the bracket things to get back to the engine zone. Is this going to be OK or does the high point creat a problem? I think it would sorta be a "trap" like a sink drain, but the fuel is under pressure when the key and pump are on. Opinions? Experiences? Comical assides? If you get hit on that side.. your fuel line are going to make a big mess... I would recommend you place it in the original location. I have -8 or some thing like that in the center tunnel. Just my 02 cents. |
Joe Bob |
Nov 12 2006, 08:12 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Replacing ANYTHING that handles fluids after 30+ years is a good thing.....just wish my HMO had that same opinion..............
Allan |
Nov 12 2006, 08:24 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Run them in the exact way they came..
Why do you want to change the routing? I replaced mine with stainless and ran it down the tunnel and out the correct opening to the FI/Carbs.... |
Trekkor |
Nov 12 2006, 08:34 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I deleted the return line and the return fitting on the tank. I ran a braided -6 SS line in the tunnel.
KT |
SGB |
Nov 12 2006, 11:21 PM
I was looking at a diff route B/C I thought (from looking at search results) that it was a pretty big deal. Granted, the car is on jackstands with the tank out, but the engine is still in there, which apparently wasn't gonna make it any eaasier...
JeffBowlsby |
Nov 12 2006, 11:48 PM
914 Wiring Harnesses Group: Members Posts: 8,661 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Hey Scott, when you do replace them, would you send them to me? I would pay for shipping.
Let me know... |
ChrisFoley |
Nov 13 2006, 06:33 AM
I am Tangerine Racing Group: Members Posts: 7,958 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I was looking at a diff route B/C I thought (from looking at search results) that it was a pretty big deal. Granted, the car is on jackstands with the tank out, but the engine is still in there, which apparently wasn't gonna make it any eaasier... Installation is no big deal Scott. You can leave the engine in, but the (right side only) exhaust has to be removed. Otherwise one person can replace both tubes in an hour. Going the long way around would definitely be more trouble. |
Lo-Fi Version | Time is now: 20th September 2024 - 04:25 PM |
