offsetting air cleaner on a dual carb/ITB install?, thnk there will be any ill effects? |
Mueller |
Nov 14 2006, 09:30 AM
Of the 2 "normal" sizes air filters used on Weber carbs or ITB's, I cannot use the smaller 4.5x7 oval due to it being a tad bit too small (I don't want to modify my air-horns again)....
the 5.5x9 oval will allow clearance, however, there might be firewall (trunk) clearance issues with the additional length. So if I offset the aircleaner, it would solve my problems..or it might create more due to getting a weird flow pattern...yea/nea??? |
Aaron Cox |
Nov 14 2006, 12:20 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
i think you need to look into Uni/Pipercross/KN cone filters ... one for each stack....
rick 918-S |
Nov 14 2006, 12:24 PM
Hey nice rack! -Celette Group: Members Posts: 20,471 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I wouldn't think the seat of the pants dyno would register an unfavorable reading. (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/driving.gif)
Crazyhippy |
Nov 14 2006, 01:13 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
Who needs air cleaners anyways????
Should be fine, not enough of an effect to worry about it. BJH |
SGB |
Nov 14 2006, 07:50 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
More filter surface = less restriction. I don't think there will be a perceptable difference at all- at least not negative.
So.Cal.914 |
Nov 14 2006, 07:54 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
I have been running it that way for a while but I did not move it as far as your
representation shows. I ovaled the holes 3/8" and mounted it there, clears the trunk bulkhead and I have not noticed any difference. |
McMark |
Nov 14 2006, 08:59 PM
I can't imagine there being much effect. I'm amazed by some of the air filters I see, and what you're proposing doesn't look half as weird.
Lo-Fi Version | Time is now: 31st May 2024 - 08:35 PM |
