Studs-How long |
Studs-How long |
Krieger |
Nov 14 2006, 08:31 PM
Advanced Member Group: Members Posts: 4,724 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Okay heres the deal I'm building a track 914/6 with a 3.0 with fender flares. I plan on running 15x7 or 15x8s all around. Not Boxter or newer style that require massive spacers. I have some cookie cutters now I start with. My rear rotors will be the 911 vented style-I don't know if these are thicker than our standard 4 bangers. I'm not certain what I will run for wheel spacers, but for PCA you get 1/4" with no points, but maybe I will use 1/2" and eat the points I'm not sure. I just want options dammit, but I don't want those bare naked studs hanging out there an extra 50mm. I have to have a little neatness. (IMG:style_emoticons/default/confused24.gif)
Cap'n Krusty |
Nov 14 2006, 10:34 PM
If you use 911SC flares, you won't need spacers with 8s in the rear, and 7s fit no problem in the front. They'll fill the wheel wells, need no spacers, and won't cost you points. Stock 911 wheel studs for alloy wheels will be just fine. There, I just saved you a TON of money. The Cap'n
jsteele22 |
Nov 15 2006, 10:53 AM
Senior Member Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
Oh, sorry. I thought you were asking about something else.... (IMG:style_emoticons/default/biggrin.gif) |
Aaron Cox |
Nov 15 2006, 12:11 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
im running 7's and 8's under massaged rear fenders.... with stock length studs....
70mm with a 1/4" spacer and open end lugnuts would be more than enough. |
Lo-Fi Version | Time is now: 4th June 2024 - 05:58 PM |
