Look out North Carolina and Eastern TN teeners, New car moving through town |
Brett W |
Nov 26 2006, 01:10 AM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
A friend of mine is bringing his baby home to Durham NC tomorrow. He is leaving from Hunstville, AL in the morning and traveling up through Cleveland, TN and through the Ocoee/ Natahala area. So if you spot a red teener, give a wave.
Attached image(s) |
JPB |
Nov 26 2006, 06:32 AM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Richard Casto |
Nov 26 2006, 08:35 AM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
A friend of mine is bringing his baby home to Durham NC tomorrow. If he doesn't already know, point out this thread to him. All of the 914 owners in his area are trying to setup a local support network... http://www.914world.com/bbs2/index.php?show...c=62587&hl= |
Brett W |
Nov 26 2006, 12:28 PM
Done. He just called and said he lost the starter side of the ignition switch. With no tools he will try push starting. If need be I will be driving up to bring aid.
maf914 |
Nov 27 2006, 08:01 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
He just called and said he lost the starter side of the ignition switch. That sounds like a typical failure. I've replaced the white nylon plastic portion of the ignition switch twice in the past. The failure symptoms were an increasing reluctance to start with the switch in the start position and when it would fire the engine would die when the key position returned to the ignition position. |
RON S. |
Nov 27 2006, 08:06 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Me thinks some one is gonna take a ride on the "Tail Of The Dragon"on his way thru. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) ron |
Brett W |
Nov 27 2006, 11:56 AM
well he made it home safely. The car is tucked in its garage. He just left the car running while he filled up, so he didn't have to push start it again. Yeah I figure that switch is going out again. I replaced it a few years ago. I told him to run a new heavier gauge wire for the starter and replace the switch. He should be good to go.
Lo-Fi Version | Time is now: 8th June 2024 - 06:41 PM |
