Light Weight, Alternator |
Randal |
Dec 1 2006, 05:46 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Is there one available for a 2.0 (4)? And do they just bolt in, or do you have to change pulleys or what. (IMG:style_emoticons/default/sawzall-smiley.gif)
THANK YOU |
Randal |
Dec 1 2006, 06:33 PM
Is there one available for a 2.0 (4)? And do they just bolt in, or do you have to change pulleys or what. (IMG:style_emoticons/default/sawzall-smiley.gif) THANK YOU (IMG:style_emoticons/default/icon_bump.gif) |
Aaron Cox |
Dec 2 2006, 12:50 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
not that i know of....
you could adapt a GM unit.... (see it done at STF) |
Mueller |
Dec 2 2006, 12:59 AM
here you go...doubt they bolt right up...less than $300
Liteweight alternators.... QUOTE AL-9101-A 35 amp, 5.6 lbs., One Wire Alternator AL-9101-B 45 amp, 6.0 lbs., One Wire Alternator AL-9101-C 65 amp, 9.0lbs., One Wire Alternator AL-9101-D 120 amp, 12.8 lbs., One Wire Alternator |
SGB |
Dec 2 2006, 05:56 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
When mine died last year at Hershey, I ended up buying another in Washington DC (actually this was Alexandria, VA) at a place valled "Arlington Armature". I expected a rebuilt stock unit but I got one that is differrent- It had an Aluminum or alloy case/ frame, 65 amp output, and a one year warrenty. Prolly 20% lighter than the one I took out. I don't know if they would always have this type,but they might have something... I haven't googled them, but they are out there I know, at least by phone if not interweb.
Cap'n Krusty |
Dec 2 2006, 06:20 PM
The OE units have an alloy case. It's the innards that are heavy. The Cap'n
Randal |
Dec 2 2006, 06:34 PM
here you go...doubt they bolt right up...less than $300 Liteweight alternators.... QUOTE AL-9101-A 35 amp, 5.6 lbs., One Wire Alternator AL-9101-B 45 amp, 6.0 lbs., One Wire Alternator AL-9101-C 65 amp, 9.0lbs., One Wire Alternator AL-9101-D 120 amp, 12.8 lbs., One Wire Alternator I'm going to call them on Monday. Thanks Mike. |
Joe Ricard |
Dec 3 2006, 07:02 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Jeg's has a small unit. 90% chance of having to modify something.
McMark |
Dec 3 2006, 03:10 PM
Lo-Fi Version | Time is now: 9th June 2024 - 07:16 AM |
