Windshield Trim Retainer Clips, Replacing... |
Allan |
Jan 3 2007, 04:52 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I have a delimma. I just talked to the glass guy about removing my windshield so I can get the car painted. I thought it would also be a good time to replace all of the trim clips because I have 1 that doesn't hold very well.
He tells me that I would be better off pulling it myself using the old wire saw trick. As I am not really looking forward to it, is there any way to replace the clips with the windshield installed? |
McMark |
Jan 3 2007, 05:11 PM
Unfortunately, replacing the clips with the window installed is doubtful. (IMG:style_emoticons/default/sad.gif) But each window install is different. It's all about how close the glass is to the clips.
toon1 |
Jan 3 2007, 06:06 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
took mine to glass shop for a front window seal replacement. Imade it prfectly clear, DO NOT CUT OFF THE WINDOW TRIM CLIPS. they cut iff three if them, reinstalled the window and now I have to pull it to install the clips.
do it yourself, it's easy, I wish I had. Also, there are some rubber stoppers that go on the bottom of the windshield to keep it from moving down |
914Sixer |
Jan 3 2007, 08:10 PM
914 Guru Group: Members Posts: 8,895 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You need to have the windshield out to replace the clips. The pin pushes into the body. You might check to see if the clips are still available. I thought I remebered another post awhile back saying they were NLA from Porsche.
dflesburg |
Jan 3 2007, 08:16 PM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
They are still available.
william harris |
Jan 3 2007, 09:25 PM
914 Restorer Group: Members Posts: 1,459 Joined: 9-January 04 From: Hamilton, MA Member No.: 1,539 |
Having done this, I don't see any way to replace the clips with the windshield still in place. I recommend using modern adhesives with a professional installer to reinstall the glass. They must heat the glass to use the modern adhesives, but the bond is a real structural bond not possible with the butyl tape.
gregrobbins |
Jan 3 2007, 09:29 PM
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
Do a search, there was a windshield post some time back and Dave Darling had some good information on what to use to reinstall the windshield.
swood |
Jan 3 2007, 09:37 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
so....the clips aren't really needed with a modern adhesive bond?
Bartlett 914 |
Jan 4 2007, 07:35 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
so....the clips aren't really needed with a modern adhesive bond? The clips hold the trim in place. The adhesive holds the glass in place. With the glass in place, the clips are difficult if not impossible to replace. Glueing the trim in place? Not so sure about this. I would not. |
SLITS |
Jan 4 2007, 07:46 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Clips, as said, are not replaceable with windshield in.
I cut all of mine off and used the rubber trim (without chrome stripe) with butyl tape. Time consuming to get it on the windshield, but it looks good. Screw the brightwork. Used 3/8" butyl tape to install windshield .... pretty easy with two people. |
william harris |
That's right, the clips only hold the chrome surround trim in place. The point is was making was to seriously upgrade the windshield bond by using the modern adhesives versus the old butyl tape which is not a strong bond. I agree that once the windshield is bonded in place it would be difficult to place the clips back in.
Lo-Fi Version | Time is now: 28th May 2024 - 12:48 PM |
