Scott-thundercat |
Member ![]() ![]() Group: Members Posts: 159 Joined: 16-October 06 From: Reno, NV Member No.: 7,049 ![]() |
man that was real fun! also fixed an oil leak from my pushrod tube that the PO tried to fix... we'll see if mine holds better than his. that alternator sucks! the new one i got had a really long stud on one of the B+ terminals, so i put some rubber grommets on it so it wouldnt ground out on the little air direction shield on the back. I couldnt believe Kragen had one in stock- and it wasnt their autolite brand so maybe it will last. this car sure does like to make me learn how to fix it.
Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,827 Joined: 20-October 04 From: Columbia, CA./ Tuolumne Member No.: 2,978 Region Association: Northern California ![]() |
man that was real fun! also fixed an oil leak from my pushrod tube that the PO tried to fix... we'll see if mine holds better than his. that alternator sucks! the new one i got had a really long stud on one of the B+ terminals, so i put some rubber grommets on it so it wouldnt ground out on the little air direction shield on the back. I couldnt believe Kragen had one in stock- and it wasnt their autolite brand so maybe it will last. this car sure does like to make me learn how to fix it. How long did it take you? I remember changing the alt. was even a bitch for me with the engine OUT of the car before installation. (IMG:style_emoticons/default/blink.gif) |
martinef1963 |
The Saga Continues... ![]() ![]() Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States ![]() |
I had to change mine like four times in less than two months - (IMG:style_emoticons/default/confused24.gif)
I finally read the thread were you had to shave one of the washers that was shorting the darn things out.... (IMG:style_emoticons/default/piratenanner.gif) After all that OJT (on the job training) I got it off & on in less than two hours.. BTW everytime was still a PITA...... (IMG:style_emoticons/default/dry.gif) regards, |
Lo-Fi Version | Time is now: 31st July 2025 - 06:56 AM |
