| swm914 |
Feb 4 2007, 02:30 PM
Member ![]() ![]() Group: Members Posts: 82 Joined: 28-January 07 From: Palmyra, PA Member No.: 7,484 Region Association: None |
Hi all, The new guy is back with another question regarding originality on a 1974. I had some nice replies yesterday on my 1st topic/question on shifter knobs. My 914 came w/o a radio. I have the original window sticker and it never had one. The lady that had it for 30 years just liked to drive it wo/ the tunes
I want to keep it original but am torn between finding an orginal radio or putting in a tastefully matching CD player. I know that is a personal thing but If I show this car will a modern unit detract in judging? If I go original, does anyone know what model(s) where installed in 1974? Some guy on ebay is selling an OEM Radio Sapphire XXV that he says is good for my year. Is that true? Also, I have alot to learn about the guts of the 914. There is no existing wiring etc. so whether I go old or new I'm not sure what the best way is to tap into power. Any opinions, advice apprciated. Thanks Steve |
| Joe Bob |
Feb 4 2007, 02:50 PM
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
No such thing as an oem radio....they came from the factory w/o one....they were sold with whatever the dealer put in them. You can get "period" correct radios like the Sapphire, but they sound like crap. Same as A/C....except they were one of three A/C units. The install was usually a hack job.
As to powering a radio....best to put them on the non switched side of the ignition. Use the recommended fuse location that your owner's manual says to. |
| Dave_Darling |
Feb 4 2007, 07:11 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Some sources cite specific Blaupunkt and Becker radios as being factory options. Others say that all radios were dealer- or importer- installed.
One option might be to hide a modern radio/CD player in the glove box. The disadvantages are that it's hard for the driver to reach, and it takes away most of your glovebox storage space. A less hidden option is to mount it under the dash. Or, if you have a center console, you might be able to make it so the face swings out to give you access to the hidden radio. Some people think the engine is the only audio you need in a 914. I far prefer to have tunes. Then again, my car was so hacked up by the time I got it that originality was never going to be a concern. --DD |
| anthony |
Feb 4 2007, 07:23 PM
2270 club ![]() ![]() ![]() ![]() Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
The radio is mounted on a plate in the dash so it would be pretty easy to save the original plate (not cut a hole in it) and save it for contests.
It would be easy enough to make a new plate out of sheet metal and glue factory looking vinyl to it. Often people sell this plate with the hole already cut and vinyl attached. Personally I enjoy the 914 with the radio off 98% of the time. I can barely hear it if the top is off. If I didn't already have a radio installed I'd probably not ever install one. The other thing to consider is whether you will drill a hole in the fender for an antenna. I wouldn't do it but I'm not sure how well those hidden antennas work. |
| Allan |
Feb 4 2007, 07:52 PM
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I say put in what you like....
I am gonna put in a heavy duty sub-woofer to off-set the noise in the cabin from the carbs. I'll never actually listen to it because I need to hear my motor to make sure it's not eating valves or cams... |
| STL914 |
Feb 4 2007, 09:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,195 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
Another option is for you to mount a Secret Radio system in your car, out of sight, and keep the dash as it came from the factory. Follow this link for more info:
http://www.online-racer.com/secretaudio.htm |
| VaccaRabite |
Feb 5 2007, 10:02 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
I want to keep it original but am torn between finding an orginal radio or putting in a tastefully matching CD player. I know that is a personal thing but If I show this car will a modern unit detract in judging? If I go original, does anyone know what model(s) where installed in 1974? Some guy on ebay is selling an OEM Radio Sapphire XXV that he says is good for my year. Is that true? Also, I have alot to learn about the guts of the 914. There is no existing wiring etc. so whether I go old or new I'm not sure what the best way is to tap into power. Any opinions, advice apprciated. Thanks Steve Hey Steve, happy to see another local on the board. Sign up for the member map if you have not. There are a few of us S. Central PA guys around here. Another option for music, without needing to cut your dash, is to mount an amp somewhere else in the car, and just have a jack to plug in your iPod (or whatever you use for mp3s). There are guys here that sell speaker kits that don't require you to mangle your doors (morphenspectra - or whatever he goes by these days). Also, I believe that Blaupunkt and Becker will rehab any of thier old radios. It might cost a little, but you would have the right radio, in an as new condition. Chances are that you could find one local to you in a pick and pull, or off ebay for pretty cheap. Zach |
| Joe Bob |
Feb 5 2007, 10:05 AM
(IMG:style_emoticons/default/hijacked.gif)
I just broke down and bought an IPOD NANO, NANO...anyways...I see it has an internal battery....is there a kit for 12v charging and interface with my auto stereo(s)? I have more than a few cars.... (IMG:style_emoticons/default/aktion035.gif) |
| Heeltoe914 |
Feb 5 2007, 10:26 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
Another option is for you to mount a Secret Radio system in your car, out of sight, and keep the dash as it came from the factory. Follow this link for more info: http://www.online-racer.com/secretaudio.htm That’s a great option I would have tried it if I Haden got mine already. I to had a period correct radio, very bad sound by today’s standards. Added a new head unit and made modes to the speaker grill to keep them looking stock. For show if all other things are perfect I think you can only loose what 2 points. So Is the rest of the car is perfect?? Maybe put the effort into rubber, trim and other details and you will show very well with any radio working in your car. Just don’t cut the door panels. |
| iamchappy |
Feb 5 2007, 10:51 AM
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
The ease in which you could swap out decks and kick panel speakers I would get the nicest Alpine head unit and 6 1/2 speakers you can afford, with James kick panel speaker pods. Swap out decks and speakers for shows.
You will spend more time shining and buffing things compared to the time and effort spent on swapping out decks and speakers. |
| So.Cal.914 |
Feb 5 2007, 11:24 AM
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
I agree. I have a 10 CD Kenwood changer up front and a Kenwood head
inside. It is a unobtrusive cassette/radio, know one seems to want to steal it because it looks like a lowley cassette player. With an amp the music can get over the top being off, the carbs, road noise and the exhaust. Nice on a long drive. George sold me my plate with matching vinyl for the radio about 10 yrs. ago, he may still have them. |
| Michael N |
Mar 4 2007, 10:34 AM
Certifiable ![]() ![]() ![]() Group: Members Posts: 1,432 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
I took a newer radio out of my car and installed this older one. No, it does not sound as good but does work well. I just love the old light that that matches the light coming from the instrument gauges. I think a modern LED screen would wreck the charm of driving the car on backroads at night.
| orthobiz |
Mar 4 2007, 10:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,762 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest
Back in the 80's I did a stereo installation in my old black 914. Took out the glove box, mounted a Benzie box. The radio protruded from the glove box door when it was inserted, made it easier to reach across to use the buttons. Took the radio out and brought it with me otherwise. I would insert a piece of rubber between the door and the radio to prevent rattling and door movement when in use (NYC has bumpy roads including potholes as big as the 914. Nothing like floating the car across one after a big storm!).
Connecting is easy. In the fuse area are empty male spade attachments just waiting for hookups to anything. My NYC road warrior had an Ungo box alarm, beeper alarm, auto antenna, extra radio, power amp hooked up. You can buy the female attachments at Radio Shack and run the wiring pretty easily under the dash. You can always reinstall the glove box later. Paul |
| smg914 |
Mar 4 2007, 11:49 AM
Sahara Beige Steve ![]() ![]() ![]() Group: Members Posts: 1,987 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
Most of the purists on this site know this but for the benifit of others;
The 914-6 could be ordered with a radio. Mine shows: Blaupunkt "Frankfurt" US-Band AM-FM" on the window sticker and the certificate of authenticity. |
| JamesBernard |
Mar 24 2007, 02:44 AM
Member ![]() ![]() Group: Members Posts: 52 Joined: 8-February 07 From: Tigard, OR Member No.: 7,513 |
http://www.swstereo.com/Products/Becker/cdr220.shtml
i found this recently and have been considering getting the matching green with my car(if possible) because it doesnt look like a NEW radio, im trying to get the whole car to stock and putting some new radio in it would ruin it, so i like this idea alot. The only thing is i was thinking about getting aftermarket speaker ports(and originals in case i sell it later) and i was going to put a small sub in the center console? just so i could listen to some music, but have the power to crank it once in a while =] |
| johannes |
Mar 24 2007, 04:48 AM
Club Porsche 914 France member since 2005 ![]() ![]() ![]() ![]() Group: Members Posts: 3,092 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
If you want to spend $$$$ this is the ultimate radio
New Becker Mexico radio with old design ... This one has Navigation, Bluetooth Telephone, iPod Ready ... (IMG:http://www.rondevries.nl/catalog/images/mexicoretro2.png) Becker was the hi end product you could have in the 916 ... http://www.caraudiodiscount.com/acatalog/b...exico_7948.html |
| Gustl |
Mar 24 2007, 06:57 AM
914 enthusiast & historian ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,084 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
IIRC I already posted this one in another thread
some guys alway claim that there were no factory installed radios - at least for the USA well then, Steve just told us, that not only his window sticker showed the radio (this could mean it's dealer installed), but also the COA says so - this definitely makes clear that it has to be factory installed, correct? and here are two pages out of the optional equipment price list from MY'71 (print# W41-010-0371-0108) they list all the factory options, including the possible radios - seperated for the 914-4 and the 914-6 and as you can see, there are also some radios marked as US Attached thumbnail(s)
| Johny Blackstain |
Mar 24 2007, 03:06 PM
Walnut Elite Stratocaster player ![]() ![]() ![]() ![]() Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region
(IMG:style_emoticons/default/popcorn[1].gif) ! Can anyone recommend the best way to get an old Frankfurt reconditioned or does anyone know how to contact the rebuilding dept at Blaupunkt? Thanks.
(IMG:style_emoticons/default/cool_shades.gif) |
| 1970 Neun vierzehn |
Mar 24 2007, 03:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
I took a newer radio out of my car and installed this older one. No, it does not sound as good but does work well. I just love the old light that that matches the light coming from the instrument gauges. I think a modern LED screen would wreck the charm of driving the car on backroads at night. Mike, I couldn't agree more. That radio looks like the one in my '70/4 except the knobs are smooth rather than "grained" as your photo shows. The radios' "owner's manual" indicates that it is a MOTOROLA radio. MOTOROLA, there's an old, vintage name for audio equipment. |
| Gustl |
Mar 24 2007, 03:34 PM
(IMG:style_emoticons/default/popcorn[1].gif) ! Can anyone recommend the best way to get an old Frankfurt reconditioned or does anyone know how to contact the rebuilding dept at Blaupunkt? check out this page: http://www.oldautoradio.com/ in the 70's section there are some Blaupunkt Frankfurt units not cheap - but lifetime guarantee ... (IMG:style_emoticons/default/wavey.gif) Gustl |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:51 PM |
