Rubber Seal Glue, What do you use? |
jagalyn |
Feb 8 2007, 10:26 AM
True Patina Group: Members Posts: 414 Joined: 31-January 06 From: Scandia, MN Member No.: 5,503 Region Association: None |
Because the windshield frame seal is no longer available and AA's seal is not ready yet, I've purchased a good used seal that is in two pieces. The left vertical piece is separated from the top horizontal piece at the factory seam. I need to glue the two pieces back together but am wondering what type of glue I should use.
Can someone who has successfully done this help? Thanks, j. |
rhodyguy |
Feb 8 2007, 10:31 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i found SHOE GOO worked pretty well. give the repair at least the 24 hours the instructions call for. i let mine sit for 3 days before i installed the seal. seems to be holding up just fine.
k |
So.Cal.914 |
Feb 8 2007, 10:40 AM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Wet suit glue, you can get it at your local surf shop...Oh...aaah, nevermind.
jagalyn |
Feb 8 2007, 10:58 AM
So.Cal.914 |
Feb 8 2007, 10:54 PM
John |
Feb 8 2007, 11:51 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Could someone in California (who knows what kind of wetsuit glue works well) send me a tube of it? Out here in Kansas City, we are ocean deprived and don't have any such thing as a surf shop. There is little demand for wetsuits here.
I too have some seals that need some repairing. I would be much obliged. Thank you very much. |
So.Cal.914 |
Feb 9 2007, 10:27 AM
For you land-locked boys & girls.
http://cgi.ebay.com/Aquaseal-WET-SUIT-REPA...3QQcmdZViewItem Free Shipping!! |
John |
Feb 9 2007, 03:24 PM
Ok,
So this is the stuff that works? I'd kinda like to know before I spend that kind of cash.... |
Katmanken |
Feb 9 2007, 07:14 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Clean the crap outa the gluing area. A PHD in glueolology taught me "A glue bond is no better than the surface the glue is placed on."
Smear fingerprint grease across a gluing surface and you WILL glue to the fingerprint grease. How strong do you think the layer of fingerprint grease is betwen the glue and the surface below the grease? His favorite cleaners were 409, acetone and alcohol. One after the other. Ken |
So.Cal.914 |
Feb 9 2007, 09:48 PM
Ok, So this is the stuff that works? I'd kinda like to know before I spend that kind of cash.... Find it yourself John. (IMG:style_emoticons/default/huh.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 06:23 PM |
