Weber three-barrel carburetors, Butterfly’s stuck closed |
burton73 |
Mar 5 2007, 10:11 PM
burton73 Group: Members Posts: 3,534 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I have Webbers 40 that were sitting for 10 years and are stuck, I have them off of the car and have tried WD40 to un stick them. I am not forcing them. Right now I am very easy because I do not want to scar anything. Does any one have magic formal to open these up and who does a good job on rebuilding Webbers? This site says the Motor Meister is no good on engine rebuilding but who does a good job on cleaning Webbers?
Bob |
Eric_Shea |
Mar 5 2007, 10:16 PM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Go directly to jail and do not pass...
NO MOTOR MEISTER! (IMG:style_emoticons/default/wink.gif) Try Harry... did you talk to his son? If you want to try and un-stick them, a gallon of Gunk Carb. cleaner is about $20 clams these days. (Try Harry) E. |
Eric_Shea |
(one b BTW) (IMG:style_emoticons/default/wink.gif)
johnlush |
Mar 5 2007, 10:49 PM
What's all this then? Group: Members Posts: 371 Joined: 26-May 04 From: Cheyenne, WY Member No.: 2,108 Region Association: Rocky Mountains |
There used to be and maybe still is a product made by Berryman. Available in lots of auto parts places. Nasty, stinky, prolly toxic to the point of altering your genomes but it really makes carburetor parts clean!
But I'm with Eric - if they are gunked up to the point that the butterflies are stuck you are for sure looking at a complete rebuild and may be way ahead by sending them to someone who is equipped to do that as well as checking/replacing throttle shaft bushings, etc. |
burton73 |
Mar 5 2007, 11:04 PM
When I did some searching on our site I found Mike was not approving of Galen Bieker my old skiing buddy because of things getting lost over there. That was the way it was 25 years ago so my thinking is nothing has changed with his dad and time. I need someone like you Eric, someone that can fix my Webbers like you are doing my brakes.
Bob |
Rusty |
Mar 6 2007, 01:50 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
When I yanked apart my carbs, I bought a gallon container of the Gunk solvent. It came with a tray (with small holes to drain the fluid) to soak the small parts.
Disassemble them as much as you can without forcing anything, and let the stuff soak for a while. Even if you don't get them unstuck, you'll help clean them up for your rebuilder and save yourself some labor. (IMG:style_emoticons/default/smile.gif) Also, for just the throttle shafts, you might try some Marvel Mystery Oil. It's good stuff, too. I know that Gint sent his Webers out a while back, but I don't remember who he sent them to. |
Flycut |
Mar 6 2007, 01:55 AM
Member Group: Members Posts: 171 Joined: 6-August 06 From: Hawaii Member No.: 6,587 |
I have Webbers 40 that were sitting for 10 years and are stuck, I have them off of the car and have tried WD40 to un stick them. I am not forcing them. Right now I am very easy because I do not want to scar anything. Does any one have magic formal to open these up and who does a good job on rebuilding Webbers? This site says the Motor Meister is no good on engine rebuilding but who does a good job on cleaning Webbers? Bob Send them straight to Art Tharen, Or soak them for Days in any Penetrating oil(Submersed) I have had great success doing this. |
Eric_Shea |
Mar 6 2007, 12:29 PM
QUOTE I need someone like you Eric, someone that can fix my Webbers like you are doing my brakes. One "B". (IMG:style_emoticons/default/wink.gif) I think I'd give Harry a shot. Les at Airpower still uses him. I thought Harry was fine with my MFI throttle bodies and stacks. I was patient but, very satisfied with the results. There is a guy out East who does Webers and MFI but I can't think of his name. Matt ??? One quick post on the boards at: www.early911sregistry.org would probably net you the results you desire (IMG:style_emoticons/default/wink.gif) |
Lightweight_911 |
Mar 6 2007, 02:39 PM
Member Group: Members Posts: 71 Joined: 7-October 06 From: London, UK Member No.: 7,008 |
r_towle |
Mar 6 2007, 02:49 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I second that vote for Eurometrix.
He is THE MAN for these carbs. I think he makes new butterflies, reams out the shaft and re-bushes it... All this work, and more is based upon special jigs and machines, so its not something that any shop can do easily, though I am sure there are some. Rich |
Eric_Shea |
Mar 6 2007, 02:59 PM
QUOTE Eric - you're probably thinking of Matt Blast @ Eurometrix: Indeed... consider my feeble memory "jogged" (IMG:style_emoticons/default/wink.gif) |
burton73 |
Mar 6 2007, 03:23 PM
I have a call into them now. They look like they can do it from their web site and with Rich’s vote and Eric’s memory Jogged this should work.
Thanks, Bob |
Joe Bob |
Mar 6 2007, 05:26 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Eurometrix.....screw the Biekers, MM, and their little dog, too....
Aaron Cox |
Mar 6 2007, 05:34 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
art thraen is also the shizzle
burton73 |
Mar 6 2007, 05:42 PM
Mike,
I spoke to Matt and he is 12 weeks out. That is fine as the work on the Engine will take me a long time and 12 weeks will go by fast. At least I trust him. He says that if he says 12 weeks it may be 13 but not more. I will soak them, as that is what takes the time. Not force them. I hope they work so I do not need to get a set of the new style Carbs that are out for $3000. I will take it slow. Bob |
Lo-Fi Version | Time is now: 29th May 2024 - 04:06 AM |
