I made an engine crank, Tested Cylinder Pressures |
tracks914 |
Nov 27 2003, 09:08 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I made an engine crank to roughly test my cylinder pressures before I completely tear down my engine. It connects to the front pulley and worked pretty well. I wanted a baseline to judge the work I am about to do.
Cylinder 1 - 112 psi Cylinder 3 - 110 psi Cylinder 4 - 112 psi (IMG:style_emoticons/default/smilie_pokal.gif) this is going pretty good for a cold engine and a hand crank. Cylinder 2 - (IMG:style_emoticons/default/sad.gif) 25psi fading to 0 psi (IMG:style_emoticons/default/headbang.gif) (insert a Hommer "dope") I guess I will have more work to do. (IMG:style_emoticons/default/smash.gif) Air is bleeding past the exhaust valve. (and yes I did check to see if there was clearance between the rocker and the valve when it was closed) It just adds to the fun of owning a teener. (and the pocket book ) (IMG:style_emoticons/default/clap56.gif) |
davep |
Nov 28 2003, 03:23 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
You might want to try getting that exhaust valve open and blowing air through the spark plug hole. or the exhaust port just in case there is a piece of crap stuck on the seat. See if you can rotate the valve.
DaveP |
tracks914 |
Nov 28 2003, 10:01 PM
Been there, done that.
No biggy though, I have my own valve grinding machine and can do my own heads. It's just more work than I had hoped, but when they are done... (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/mueba.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:32 PM |
