| sk8kat1 |
Mar 21 2007, 03:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
is it a bad thing to put a little blue loc tite on the cv bolts?
| Allan |
Mar 21 2007, 03:49 PM
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
If you can get the threads that clean go ahead...
| sk8kat1 |
Mar 21 2007, 04:05 PM
If you can get the threads that clean go ahead... i bought new cv bolts (IMG:style_emoticons/default/biggrin.gif) |
| Bartlett 914 |
Mar 21 2007, 04:06 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
If you can get the threads that clean go ahead... It is usually best to use new lock washers. Blue locktite won't hurt. Are you really putting these in already or are you planning ahead. Last I heard you were having difficulties putting the engine and transmission together. |
| sk8kat1 |
Mar 21 2007, 04:10 PM
If you can get the threads that clean go ahead... It is usually best to use new lock washers. Blue locktite won't hurt. Are you really putting these in already or are you planning ahead. Last I heard you were having difficulties putting the engine and transmission together. I also bought new serated washers and I stayed up late last night got them together and I am all set with the engine / trans .. I am cleaning up what I need to before the install ... heck I even was able to gethe the rear sway bar links back on the shock bolts!! (IMG:style_emoticons/default/biggrin.gif) |
| sk8kat1 |
Mar 21 2007, 04:12 PM
I should be tring to put the engine in today / tonight.. should be fun !!
then I just have the mess that looks like r2-d2- puked to reconnect all the wires and hoses (IMG:style_emoticons/default/alfred.gif) then start her up!! |
| akellym |
Mar 21 2007, 04:16 PM
Eyes Of The Deep Battle ![]() ![]() ![]() Group: Members Posts: 598 Joined: 25-July 04 From: Annandale, MN Member No.: 2,395 Region Association: Northstar Region |
I use blue lock tight on mine, works well. I don't use the gaskets, just silicon. Never had one come loose yet.
| Bartlett 914 |
Mar 21 2007, 04:49 PM
If you can get the threads that clean go ahead... It is usually best to use new lock washers. Blue locktite won't hurt. Are you really putting these in already or are you planning ahead. Last I heard you were having difficulties putting the engine and transmission together. I also bought new serated washers and I stayed up late last night got them together and I am all set with the engine / trans .. I am cleaning up what I need to before the install ... heck I even was able to gethe the rear sway bar links back on the shock bolts!! (IMG:style_emoticons/default/biggrin.gif) That is good news Mike. You are ahead of schedule. Lots of luck. What is with the MPS (The one with the rattle)? Was that your original one or did that come with the motor? |
| sk8kat1 |
Mar 21 2007, 07:46 PM
engine and trans is in!!!! the mps is the one that came with the new engine .. I will be calling brad
| ws91420 |
Mar 21 2007, 08:02 PM
Yes I have one a Lensley 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
Look in member vendors section for Dr Evil's cv bolts. he has them so you can safety wire them from backing out. He provides the wire and instructions on how to do it.
| Bartlett 914 |
Mar 21 2007, 10:03 PM
engine and trans is in!!!! the mps is the one that came with the new engine .. I will be calling brad Way to Go! I can't wait to see your car running. Keep us posted. (IMG:style_emoticons/default/beerchug.gif) |
| BigDBass |
Mar 21 2007, 10:29 PM
Dumb Question Champion ![]() ![]() ![]() Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
QUOTE I can't wait to see your car running. Keep us posted. (IMG:style_emoticons/default/agree.gif) Great progress Mike! |
Lo-Fi Version | Time is now: 7th December 2025 - 09:33 PM |
