r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
What is the original gasket material between the engine tin.
Not the rubber engine bay stuff, but the actual gasket material between each piece (If any) and the gasket between the tin and the fan shroud?? Rich |
jwalters |
Sooo Close....... ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe ![]() |
What is the original gasket material between the engine tin. Not the rubber engine bay stuff, but the actual gasket material between each piece (If any) and the gasket between the tin and the fan shroud?? Rich That would be the artist formally known as "AIR" ....... My gasket of choice "RTV" (IMG:style_emoticons/default/biggrin.gif) |
Pat Garvey |
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,900 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States ![]() |
What is the original gasket material between the engine tin. Not the rubber engine bay stuff, but the actual gasket material between each piece (If any) and the gasket between the tin and the fan shroud?? Rich First time I did mine, which was mid-70's, I bought all the factory pieces - which are black foam. Cost a bunch then. Seriously doubt they are still available. Next time (mid-80's) I went to Sears (yeah, that's right) & bought black foam window insulation. Recollection is that it was about 1/4 inch, maybe 3/8's dense foam insulation. Worked well, doesn't show and, most importantly, has held up well. There should be a piece between every piece of tin & mating surface. Probably best to use 3/8 where the tin mates with the blower housing. Just make sure it's the dense stuff. |
r_towle |
What is the original gasket material between the engine tin. Not the rubber engine bay stuff, but the actual gasket material between each piece (If any) and the gasket between the tin and the fan shroud?? Rich First time I did mine, which was mid-70's, I bought all the factory pieces - which are black foam. Cost a bunch then. Seriously doubt they are still available. Next time (mid-80's) I went to Sears (yeah, that's right) & bought black foam window insulation. Recollection is that it was about 1/4 inch, maybe 3/8's dense foam insulation. Worked well, doesn't show and, most importantly, has held up well. There should be a piece between every piece of tin & mating surface. Probably best to use 3/8 where the tin mates with the blower housing. Just make sure it's the dense stuff. I was hoping that was the case, I planned to do that, just curious. i tinker to much for RTv gasket....it would piss me off to much to take it apart yearly... Rich |
Lo-Fi Version | Time is now: 31st July 2025 - 08:54 PM |
