fuel pump fuse blows, The saga continues |
computers4kids |
Mar 24 2007, 05:44 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Question2: 2.0 transplant motor started-up then...
Turn key, injectors click then crank and engine ran for a little bit. I turn off engine to check for fuel leaks etc...car wouldn't start...no fuel pump noise...fuse blown...replace fuse...blew again...swapped relays...fuse blew again?? So what do you think? Car ran perfectly before motor transplant (1.8 to 2.0). Has the fuel pump gone south...or could there be another issue? PS I disconected the heater blower just in case it was part of the issue. |
r_towle |
Mar 24 2007, 05:59 PM
Custom Member Group: Members Posts: 24,623 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
check to see that the fuel line are connected correctly...dont know really, but maybe it built up to much pressure on the wrong side...
Again, dont know...but I would check it if it was me. Rich |
Dave_Darling |
Mar 24 2007, 06:23 PM
914 Idiot Group: Members Posts: 15,047 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Find the wire that plugs into the aux air regulator and unplug it. Tape it up so it can't short to ground. It is on the same circuit as the pump, and if it shorts out it will pop the fuse.
--DD |
computers4kids |
Mar 24 2007, 10:30 PM
Find the wire that plugs into the aux air regulator and unplug it. Tape it up so it can't short to ground. It is on the same circuit as the pump, and if it shorts out it will pop the fuse. --DD Dave...you were right on the money...the AAR was shorting out...swapped it for another one that was good...unfortunaltely I now have discovered my MPS won't hold a vacumm and the engine just floods. |
Aaron Cox |
Mar 24 2007, 10:32 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
Lo-Fi Version | Time is now: 20th September 2024 - 04:41 PM |
