Rebuilt 1.7 Heads, Pulled an exhaust stud |
rigglet |
Mar 25 2007, 01:42 PM
Member Group: Members Posts: 149 Joined: 28-November 06 From: Westfield, Indiana Member No.: 7,272 Region Association: Upper MidWest |
Looing for someone/someplace that rebuilds heads for the 1.7. I was looking for a possible exhaust leak when I found the source of my issue. Unfortuantely I have pulled an exhaust stud from the head. I'm sure I could find someone to repair it, but my thought would be that since I'm going to have to drop the engine I would go ahead and replace the heads and rings. Figure the motor will be out anyway. (IMG:style_emoticons/default/idea.gif)
I live in the Indianapolis area. Please let me know if you know of any shops or individuals who might be up for the task. Thanks! |
jwalters |
Mar 25 2007, 02:04 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
Looing for someone/someplace that rebuilds heads for the 1.7. I was looking for a possible exhaust leak when I found the source of my issue. Unfortuantely I have pulled an exhaust stud from the head. I'm sure I could find someone to repair it, but my thought would be that since I'm going to have to drop the engine I would go ahead and replace the heads and rings. Figure the motor will be out anyway. (IMG:style_emoticons/default/idea.gif) I live in the Indianapolis area. Please let me know if you know of any shops or individuals who might be up for the task. Thanks! This CAN be easily repaired engine still in car.... Most local FLAPS have the kit needed to helicoil in-place - I have done it, and my mechanically challenged (at the time) friend did it also --- |
sww914 |
Mar 25 2007, 02:05 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
You don't necessarily need to pull the engine.
You can get a "step stud" at an aircooled VW shop, it's an 8mm stud on one end and 9mm on the other. You can just run a 9mm tap up the hole and install the stud in the new threads. Mine was so wallowed out that I only had 3 good threads up at the top of the hole after tapping it, so in the interest of making it to the track the next day, I screwed it in with a thick coating of JB Weld. I didn't think it would make it through the weekend, but it's still holding after 4 years. If you can't find a stud, I'll mail you one, I bought 6 while I was there, I've only used 2 and given one away. |
Bartlett 914 |
Mar 25 2007, 02:39 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
You don't necessarily need to pull the engine. You can get a "step stud" at an aircooled VW shop, it's an 8mm stud on one end and 9mm on the other. You can just run a 9mm tap up the hole and install the stud in the new threads. Mine was so wallowed out that I only had 3 good threads up at the top of the hole after tapping it, so in the interest of making it to the track the next day, I screwed it in with a thick coating of JB Weld. I didn't think it would make it through the weekend, but it's still holding after 4 years. If you can't find a stud, I'll mail you one, I bought 6 while I was there, I've only used 2 and given one away. You must have enough good threads in there to work. JB weld will not hold up to that temperature. I am sure it is long gone by now. Helicoil works. There is another device I have used called a Keylock Insert. McMaster Carr sells it. |
rigglet |
Mar 26 2007, 11:05 AM
Thanks for all the responses. I think I will give the helicoil repair route a try. Anyone know if I can do a hybrid solution of helicoil and "step stud"? Looking at it a bit closer it looks like it may have been helicoiled previously and that is what got pulled out. My thought (having never done helicoil repair) is that I will need to use a large helicoil and then use a larger step stud afterwards.
Thoughts? |
jwalters |
Mar 26 2007, 06:48 PM
Thanks for all the responses. I think I will give the helicoil repair route a try. Anyone know if I can do a hybrid solution of helicoil and "step stud"? Looking at it a bit closer it looks like it may have been helicoiled previously and that is what got pulled out. My thought (having never done helicoil repair) is that I will need to use a large helicoil and then use a larger step stud afterwards. Thoughts? Keep it as small as you can at this point......IF it has been heli'd once, it has already been drilled and threaded. Go too much and you could end up punching clear through to the combustion chamber ... <OUCH> Go easy with it.... |
Lo-Fi Version | Time is now: 8th June 2024 - 01:32 AM |
