Muffler Question, Do they"fill" up ? |
jim_hoyland |
Mar 29 2007, 07:20 PM
Get that VIN ? Group: Members Posts: 9,317 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I've noticed my bursch seems to have gotten quieter over the past three years, is that from soot building up in it ?
When I still had the catylitic converter installed, it would clog up in 2-3 years and have to be replaced. Any first hand experiences will be appreciated Jim |
Cap'n Krusty |
Mar 29 2007, 08:29 PM
WHAT?????? I've never seen that. If you're sooting up a muffler bad enough to plug it, you've got MAJOR engine problems. Busted cats can do that, but that's chunks, not soot. The Cap'n
Joe Ricard |
Mar 29 2007, 09:12 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
My tangerine has changed tune a bit in the last 2 years. sort of mellowed a bit.
jim_hoyland |
Mar 29 2007, 09:46 PM
So the change in tone/sound is probably due to the metal itself...OK
Elliot Cannon |
Mar 29 2007, 11:34 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
So the change in tone/sound is probably due to the metal itself...OK You're probably losing your hearing. (IMG:style_emoticons/default/laugh.gif) Cheers, Elliot |
So.Cal.914 |
Mar 29 2007, 11:38 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Its shrinking from the heat...Like a wool sweater in the dryer.
Allan |
Mar 30 2007, 11:34 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
So the change in tone/sound is probably due to the metal itself...OK You're probably losing your hearing. (IMG:style_emoticons/default/laugh.gif) Cheers, Elliot (IMG:style_emoticons/default/chairfall.gif) |
Brando |
Mar 30 2007, 12:16 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
So the change in tone/sound is probably due to the metal itself...OK You're probably losing your hearing. (IMG:style_emoticons/default/laugh.gif) Cheers, Elliot (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/av-943.gif) Actually Jim, if anything happens to mufflers they rot away inside, or become plugged if/when your catalytice converter's filament turns to fragments. Change in tone? Maybe. More restrictive? Doubtful without a cat. |
pfierb |
Mar 30 2007, 06:55 PM
oldest member Group: Members Posts: 606 Joined: 1-May 05 From: The sign of good government in Connecticut is to keep raising taxes Member No.: 4,008 |
Years ago when I was in the muffler business I remember it was quite common for mufflers to loose their new sharp loud sound as they aged....was nothing more than a carbon build up inside.
jim_hoyland |
Mar 30 2007, 09:45 PM
messix |
Mar 30 2007, 10:14 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
Years ago when I was in the muffler business I remember it was quite common for mufflers to loose their new sharp loud sound as they aged....was nothing more than a carbon build up inside. Can I clean it out after removing the muffler ? sorry but (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) but thats funnay |
Lo-Fi Version | Time is now: 4th June 2024 - 06:19 PM |
