Front side marker light, 500 pound gorilla strikes again |
Pat Garvey |
Apr 3 2007, 08:27 PM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
While positioning a jackstand under my 914, I inadvertantly hit the RS side marker light with my shoulder. Since the mounting pins are ancient, they broke & the assembly flopped out on the fender.
I was engrossed with other things & simply pulled it loose so I wouldn't do any paint damage. Now I'm not certain how the wires re-hook. Have the last of my new ones (those damned pins are so flimsy), as pictured, but need some consoling as to the wiring hookup. See the pic & tell me what you think. Thanks - Pat Attached image(s) |
Crazyhippy |
Apr 3 2007, 09:01 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
electrically it shouldn't matter.
I believe your caption is correct though. BJH |
Porsche Rescue |
Apr 3 2007, 11:05 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
Ground to the single spade on the upper right in your pic. Positive to other terminal which contacts the center contact on the bulb.
Pat Garvey |
Apr 4 2007, 08:02 PM
Thanks guys! Just needed to be certain - it's been years since I totally removed one of these. Looked straightforward, just needed my hand held!
Thanks again Pat |
Lo-Fi Version | Time is now: 28th May 2024 - 01:07 PM |
