The new toy is coming! |
michaelt55 |
Apr 20 2007, 08:54 PM
Graduate of Life's experiences Group: Members Posts: 438 Joined: 2-September 06 From: Richmond, Texas Member No.: 6,753 Region Association: None |
well..my 1972 914 V8 will be here Sunday. I am excited...... (IMG:style_emoticons/default/piratenanner.gif)
BODY -Rayco FRP front fenders -Mitcom 916 rear quarter panels -P.B. Tweeks FRP flared rocker panels ENGINE/DRIVETRAIN -1970 Rover/Buick all aluminum 215-V8 -STD bore, 10.5-1 (stock) comp ratio -Cyl heads-ported exaust ports, 3 angle valve grind with hi-retainers-shaft rocker stands shortened .060"-pushrods shortened .125" for geometry correction. -Camshaft-M-488 custom ground by Shadblot engineering(Vancouver B.C.) C/W hydraulic lifters -Spheroidal graphite iron crankshaft, 5 main journal center, thrust mains, .010" under - rods ground .001" -Hi volume oil pump, Buick v8 filter housing -Facet electric fuel pump-GM canister filter -Offenhauser alum intake -500cfm Carter carb C/W electric choke -Buick distributer with Unilite conversion -Kennedy engineered product #1000 Rover to Porsche adapter -KEP 2400# max pressure plate -KEP throwout bearing -V.W. 200mm clutch disc -Custon h.d. radiator w/ twin Spals -Toyota Corolla heater ELECTRICAL -Hella H-4 Q.I. headlites -Eurolens rear tail lites -Tach converted to 8cyl -Mechanical oil pressure and water temp -Electrical oil temp and cyl head temp -Alpine CD with JBL audio speakers -Electric windows -Keyless entry SUSPENSION -H AT H Carrera 19mm adj front sway bar -Addco 16mm rear sway bar -140# rear springs (100 stock) -Stock front torsion bar -Koni adj front and Koni H.D. rear shock absorbers -BMW 320i front brake conversion -Stock Porsche rear calipers -All four calipers have stainless steel liners and completely rebuilt. -Adj proporsioning valve -19mm 911 master cylinder -All rotors have been crossdrilled -All flex lines are braided stainless steel -Pagio performance brake pads, all four wheels -Carrol Shelby Mini-Europa wheels 7/15 front 8.5/15 rear -Custom roll bar with rear chassis supports all that... Now if I can just clear a spot out of the garage for the new arrival!! Come on guys... buy my 73!!! Michael |
914Sixer |
Apr 20 2007, 09:05 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Baaadddd !!!!
michaelt55 |
Apr 22 2007, 06:48 PM
well, the V8 arrived today...its looking pretty awesome. Took it for a short cruise around the neighborhood (no plates/inspection) and I was impressed with the little 215 V8. Great mid range torque and sounds good at 4000 rpm. As soon as I register it, I have some little things to fix and improve upon. Other than that, its a great pruchase. (IMG:style_emoticons/default/smilie_pokal.gif)
the Iceing on the cake was what was in the car.....a full set of factory repair manuals!!. Also several porsche books and a letter of mods by the PO. The bad part.. the black 73 is out of the garage with a tarp over it. First time exposed to the elements!!! (IMG:style_emoticons/default/confused24.gif) I am stoked!!!!!! (IMG:style_emoticons/default/piratenanner.gif) Michael |
Aaron Cox |
Apr 22 2007, 06:51 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
pics?!?!
jonferns |
Apr 22 2007, 07:14 PM
Advanced Member Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States |
michaelt55 |
Apr 22 2007, 08:28 PM
pictures will posted in the next couple of days....
Michael |
Lo-Fi Version | Time is now: 8th June 2024 - 02:12 PM |
