Timeing mark, On pully T-IV |
trojanhorsepower |
Dec 5 2003, 09:26 PM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
Can anyone point me to a thread or tell me where the mark should be positioned in space. I only have the pull on right now to set the valves so I have no reference point (not that I would recognize one if I saw it). I have the motor on a stand so standing in front of the pulley looking over the top of the motor toward the fly wheel were should the mark be for #1 at TDC? Right now it appears to be at about 200 deg. Is this correct?
Thanks -Pete |
Bruce Allert |
Dec 5 2003, 09:48 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
For a 1.7 or 2.0 this link tells how to find it and gives some purty gud pictures.
http://www.pelicanparts.com/techarticles/9...alve_adjust.htm here's the template link for marking the timing mark on the fan http://www.pelicanparts.com/techarticles/9.../914_timing.htm good luck... it's not too hard to find. ...........b |
trojanhorsepower |
Dec 5 2003, 10:04 PM
Thanks Bruce,
I'll look into to it in the morning. I was going to stay up and work on it but... (see post "25 ways to tell .... ") Night all -Pete |
Brad Roberts |
Dec 5 2003, 11:41 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
QUOTE Whatever you have heard in the past from other people, do not turn the engine using the impeller fan. It's just not worth breaking a fan blade when there is a much better approach. Bullshit. Grab the fan by HAND and turn it if you dont use the road wheel method. The fan blades only break when you use a friggin screw driver in the fan to turn the engine over. A engine with 5k miles on it will turn over by hand (grabbing the top of the fan and pulling towards the passenger side (backwards of the rotation 1/2/3/4) B |
Bruce Allert |
Dec 6 2003, 01:06 AM
After looking at this article again I see that it has been updated, pictures too. The old article said, as I recall, "do not use a screw driver in the fan blades to turn the engine over. "
I agree, Brad, turning the engine over by hand using the fan wouldn't seem to be cause for breaking blades. Must've been an oversight on the proof reading (IMG:style_emoticons/default/laugh.gif) ............b |
trojanhorsepower |
Dec 6 2003, 10:22 AM
Thanks guys
Since my motor is on a stand (no injectors, spark plugs or trans) I have been using the pulley part of the fan to turn the motor over. The problem I was having is there are no stationary references with out the fan housing and trans bell housing to reference when checking the marks. I am thinking the marks should be rough 180 deg. or straight down. Mine is past that by many deg., I will recheck my books and the tech articles when I get back over there this afternoon. Thanks again -Pete |
Lo-Fi Version | Time is now: 4th June 2024 - 12:18 PM |
