Clutch Disk Thickness, Anyone measure a new one?? |
tracks914 |
May 9 2007, 08:28 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I need to replace my clutch, it's getting out of adjustment.
I have two other ones here that I can put in but I don't know what kind of life they will have. They look good but without the thickness I don't know if I will be wasting my time putting one in. If one has better than 50% life left in it, for the 2000 miles a year I drive it, I think I will put it in. Anyone have the thickness of a new one? BTW '72 1.7 but I don't think it matters. Thanks |
mrhurtalot |
May 9 2007, 08:58 PM
VRRRRRRROOOOOOOOOM! Group: Members Posts: 323 Joined: 5-October 06 From: Yukon, Oklahoma Member No.: 6,996 |
id pull my new one out. but i just put it in and iwant to drive!
craig downs |
May 9 2007, 08:59 PM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
My brand new disc measures .400 or 10mm thick.
tracks914 |
May 9 2007, 09:34 PM
The used one I have on the bench measures .356"
I'll have to compare that with the one I take out. Then again if I can get a new one for about $75 I'll just do that and be done with it. |
sww914 |
May 9 2007, 09:56 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
Brand new one here measures 10mm or .392".
LvSteveH |
May 9 2007, 10:46 PM
I put the Poor in Porsche Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
If I recall correctly, the old school rule of thumb is to replace it if under 7mm. Quick and easy check is to see if a 7mm open end wrench fits over the disk.
tracks914 |
May 10 2007, 04:45 PM
This disk measures 9mm but there is some deflection in the metal plates between the 2 disk halves.(all the waty around) If I compress the disk it measures 8.47mm all the way around. Is this normal?
Justinp71 |
May 10 2007, 06:14 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
This disk measures 9mm but there is some deflection in the metal plates between the 2 disk halves.(all the waty around) If I compress the disk it measures 8.47mm all the way around. Is this normal? ???? My brand new one was the same way, something like 9.8mm and 9.5mm compressed. That was the $68 6-spring, 4-spring replacement disk. |
tracks914 |
May 10 2007, 07:51 PM
[/quote]
My brand new one was the same way, something like 9.8mm and 9.5mm compressed. That was the $68 6-spring, 4-spring replacement disk. [/quote] Man you SoCal guys $68. I just priced a 4 spring SACHS for $180CAN here in Timmins. I think if I go new I will go with the $60 on Ebay. |
tracks914 |
May 10 2007, 07:53 PM
I just pulled the one off my spare 1.7.
I measured it at 9.60mm and 9.10 compressed. It still has the writing on one side of the disk so I think I will put it in for now. I think I just got lucky. |
Lo-Fi Version | Time is now: 23rd May 2024 - 03:28 PM |
