Generator light |
Generator light |
ruddyboys |
May 13 2007, 07:24 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
Wondered why my generator light never came on, It's because there aint any!!! The battery does charge so I looked behind the dash for a roaming extra socket and buld by no gots. What are the color of the wires that go to the socket?
bd1308 |
May 13 2007, 10:11 AM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
thats really odd. Theres a blue wire that needs resistance (from a bulb) that makes everything start(on the alternator)
SirAndy |
May 13 2007, 03:50 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
thats really odd. Theres a blue wire that needs resistance (from a bulb) that makes everything start(on the alternator) (IMG:style_emoticons/default/agree.gif) it's a blue wire. the second one should be red/white. the blue wire goes to pin 2 on the relay board. the circuit won't function correctly without the bulb ... (IMG:style_emoticons/default/bye1.gif) Andy PS: grab yer haynes manual ... '74 (if you're not afraid of current flow diagrams), page 175, upper left corner, K2 is the bulb otherwise, use the diagram on page 164 (which is for a '73, but that part is identical) |
ruddyboys |
May 13 2007, 05:11 PM
found the socket way down behind the dash, BUT I tested the blue end wire with the blue wire at the voltage reg and there was a break somewhere, and I found it!!!! The PO cut the wire under the console, split it into 2 wires and nither of them conected to the socket. I fished the wire from the socket and splice all together and it works...
Toast |
May 13 2007, 06:52 PM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 23rd May 2024 - 09:01 AM |
