Fuel Pump progress, Success - one small step at a time |
plas76targa |
Jun 13 2007, 06:56 AM
Senior Member Group: Members Posts: 885 Joined: 22-February 04 From: Frederick, MD Member No.: 1,700 Region Association: MidAtlantic Region |
Dr Evil and Crash914 will appreciate this. I finally got that darned fuel pump removed. The first of two nuts holding it on came off easily. Why is it always the remaining item that puts up the good fight? Every time I turned the nut the stud would turn with it. how to beat this problem? I took the other nut and 'borrowed' a third one from the ground at the left front headlight, backed those two together real tight to hold the stud and tediously worked on the stubborn last nut. (IMG:style_emoticons/default/beerchug.gif)
Not an easy task in the stock location! now to test the used FP I have and get put it all back together. Cross my fingers and on to the next problem. Anyone have a picture of the stock rubber mounts for a fuel pump on a 72? |
Dr Evil |
Jun 13 2007, 11:53 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
About damn time (IMG:style_emoticons/default/rolleyes.gif) Dont for get to put oil in your tranny....have you done that yet?
Didnt I have to engineer your mount and stuff? Its been so long I forget. (IMG:style_emoticons/default/wink.gif) What do you need now? |
plas76targa |
Jun 13 2007, 05:42 PM
About damn time (IMG:style_emoticons/default/rolleyes.gif) Dont for get to put oil in your tranny....have you done that yet? Didnt I have to engineer your mount and stuff? Its been so long I forget. (IMG:style_emoticons/default/wink.gif) What do you need now? yep - way overdue. oil is in tranny already. Not sure what you did to the mount other than comment it's fuey. The left side as you look at the pump - towards front or the car, wasn't even mounted or had pulled out. The rear screw was holding the whole thing on. Guess I need to see what is SHOULD look like, thus the request for pics of the stock mount - preferrably with the fule pump removed. how'd yer test go? |
type47 |
Jun 14 2007, 07:20 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
i think there are 2 FP rubber mounts available. the OEM is round and goes for about $24 and the other has like a 6 sided rubber part that goes for $6. don't quote me on the prices.
Dr Evil |
Jun 14 2007, 09:28 AM
You can probably get the shock mounts at your FLAPS or Home Depot for low $.
plas76targa |
Jun 14 2007, 11:33 AM
Marlow |
Jun 14 2007, 08:49 PM
Member Group: Members Posts: 311 Joined: 14-August 03 From: Manassas, VA Member No.: 1,027 |
$24 for the round ones? ouch!
Not sure if these are OEM but $4.12 sounds better to me. Fuel Pump Mount Attached image(s) |
plas76targa |
Jun 14 2007, 10:33 PM
Joel - awesome. I just ordered two... I'll let you all know how they work!
this place is great! |
Lo-Fi Version | Time is now: 10th June 2024 - 03:08 PM |
