Intermittant Wiper Installation Question, Can I test the Signal Wire ? |
jim_hoyland |
Jun 20 2007, 09:17 PM
Get that VIN ? Group: Members Posts: 9,315 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I have the intermittant wiper harness ready to install and want to test the signal wire first. I untaped the brown wire/blk stripe that was folded back on the loom going toward the wiper motor. Should I get 12 v signal in that wire with the ignition on, and wiper switch in the full-down position ( i removed the tap) ?
I stuck a grounded test light into the connector with the switch on and got NADA Perhaps someone who has does this retro-fit can halp.The wiper switch is either a late model VW or 924. It runs the washer pump in the pull-bak position Thanks, Jim |
904svo |
Jun 20 2007, 10:40 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
I believe the wipers have to turn on first for it to work.
jim_hoyland |
Jun 20 2007, 10:46 PM
I believe the wipers have to turn on first for it to work. I ran the wiper slow first, then moved the switch position to one below the off. I guess I'm wondering if the brown wire/blk stripe is a ground ? Looking for someone who has done this install and did some trouble shooting Jim |
SirAndy |
Jun 20 2007, 11:06 PM
Resident German Group: Admin Posts: 41,670 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Looking for someone who has done this install and did some trouble shooting if i recall correctly, that wire is a ground wire ... it'll provide ground for the relay through the wiper assembly. the wire will only ground out with the lever all the way down (after you broke off the tab) ... take your multimeter and see if you get a closed circuit to the chassis with the lever down ... (IMG:style_emoticons/default/bye1.gif) Andy |
jim_hoyland |
Jun 21 2007, 09:23 PM
Looking for someone who has done this install and did some trouble shooting if i recall correctly, that wire is a ground wire ... it'll provide ground for the relay through the wiper assembly. the wire will only ground out with the lever all the way down (after you broke off the tab) ... take your multimeter and see if you get a closed circuit to the chassis with the lever down ... (IMG:style_emoticons/default/bye1.gif) Andy That's good. Thanks for the info. |
Lo-Fi Version | Time is now: 3rd June 2024 - 11:30 AM |
