911 901 in a bus |
911 901 in a bus |
bd1308 |
Jun 22 2007, 04:05 AM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
I know its possible, I just know it.
5 speeds in a bus would be helpful. Only Q would be if the final drive in a bus tranny would be the same in a 901? in 5th (and 4th) going same speed, RPM seems to be around same in both the 914 and my buddy's bus. I'm thinking that the 901 would put up with a tad more abuse. |
URY914 |
Jun 22 2007, 06:44 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,951 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Go to thesamba.com and look in the forum section. They are as wacked out as us when it comes to buses.
type11969 |
Jun 22 2007, 06:56 AM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
901 vs a Bus tranny? No way the 901 will put up with more abuse. Those Bus trannys are what guys in the dunes are using, I doubt you will see many 901s out there.
markb |
Jun 22 2007, 08:47 AM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
PM Cap'n Krusty. He can probably tell you more than you want to know about it. He did it with the ThunderBus.
Bleyseng |
Jun 22 2007, 08:59 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
you want 5 speeds? (IMG:style_emoticons/default/WTF.gif)
Get a Euro spec 091 5 speed tranny, its more like a close ratio box as its the same final drive .89. Did you ever locate those shifter parts?? I can use them as I will be rebuilding my 091 in two weeks. |
bd1308 |
Jun 22 2007, 01:46 PM
Geoff,
Its a metal shifter ball ( instead of plastic) that can be bought online from somewhere? There's also a short shift kit I can pick up this weekend I'll let you know |
Lo-Fi Version | Time is now: 1st June 2024 - 07:09 PM |
