Open Car Trailer Advice, Trailer Advice |
0396 |
Jun 30 2007, 12:43 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
All, since I have no knowledge of car trailers.. any advice out there? Here's some questons that I HAVE: * Who and why one brand vs another * Price points that I should be aware of * Surge brakes vs elec * 2 inch ball vs 2 5/16 * alum vs steel And any other useful info.. currently looking at trailex @ 7 k for an open trailer. Ok experts.. |
messix |
Jun 30 2007, 12:59 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
wow where to start?
you get what you pay for. look for a c-channel or box tube frame, bigger thicker the better. some have the deck support made from flimsy angle iron[ bad]. surge brakes will be more $. electric is fine. 2" ball ok if max out under 5k lbs, i would want to trust 10k on less than 2 5/16" although the key is the shank size [the part that bolts to the hitch and slides into the receiver] steel will cost alot less, but weigh more. things that you want that are usually extra cost, brakes on both axels, tie down points on the deck or on the deck side, ramps, treated decking. beaver tail, backend slants down to make loading low clearance easier. thats all i could think off right now. |
messix |
Jun 30 2007, 01:03 AM
just looked at the trailex.... spendy !
Van914 |
Jun 30 2007, 05:05 AM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
Trailex is what I have. Many advantages to Alum. trailers.
Weigh less 1 person can move it around Tow vehiecle can be a V6 Mine tows great at 70 - 75 with my MDX Look for a used one Good luck Van914 |
BarberDave |
Jun 30 2007, 06:29 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
My 2 cents: 16 ft. if you are only using for a 914 the 18ft. is way to big. Toolbox or something on the front to protect the trailered vihicle from road debris thrown up by wheels of the tow vihicle. Also front half of the floor covered with Alum. plate for the same reason as above. Surge or elec. brakes???? I for one would like more discusion here on the pro and con of both. Brakes are a bad place to cheap out!!!! Lights ,l are L.E.D. standard or optional , if optional worth the extra price, just follow 2 simis one with L.E.D.'s and one without you will see the difference . Dave (IMG:style_emoticons/default/slap.gif) |
degreeoff |
Jun 30 2007, 06:36 AM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
Another question....why new? I bought my steel deal here from a pelicanite @ 1100 buck, elec brakes, dual axle, slant rear box steel C channel and it was 6 years old..I added a floor on the center and rails to the side for a "dual" trash/car hauler...keep your eyes open you'll find a good one for WAY less than 7 K
Johny Blackstain |
Jun 30 2007, 06:56 AM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
I'm familiar w/ "Featherlight" & electric brakes. All aluminium, very light (1350lbs/16'), very strong, removeable fenders & the brakes rock. Perfect economical set up for towing a 914 w/ a S-10 Chevy. Install an electronic brake controller inside the truck & the only time you feel anything is going uphill, gravity, but never downhill w/ those brakes. Easy to move around by yourself & low enough to drive up on & not hurt anything underneath the car.
(IMG:style_emoticons/default/cool_shades.gif) |
Joe Ricard |
Jun 30 2007, 07:30 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
We use a big heavy steal 18 ft. no brakes , does have beaver tail and metal floor with open center section. LED's Requires 10 ft long ramps to get 914 on the trailer (just barely)
Takes a 4.6L Ford F150 to marginally get the job done. makes 10 MPG towing. Not my rig and I would not go this route as there are lots better choices. |
73Phoenix20 |
Jun 30 2007, 07:54 AM
Member Group: Members Posts: 334 Joined: 15-June 05 From: Michiana Member No.: 4,283 |
BEST Car hauler is the U Haul Auto Transport... Good surge brakes, open chassis to help in tie down, low to the ground for easy loading, no storage issues, and if you get to know the local dealer, they will work with you on reservations and one day trips...
But, if you have to have your own, an Interstate 1 18' with 2' beavertail, dual brake axles, boxed frame (as above), and electric brakes is my choice... medium heavy, so it rides and pulls well, and with the electric brake controller you can set it up for any load weight, for nice straight stops every time. Surge brakes can be a little "iffy"... either all on or not at all... they don't have the progressive braking feel of electrics. Featherlights are nice, but sort of spendy... the Interstate 1 , with brakeaway kit, and a winch, came in at $3,000.00 new out of the box, with HD 15" wheels and HD Radial Tires... |
Johny Blackstain |
Jun 30 2007, 08:09 AM
Featherlights are nice, but sort of spendy Unfortunately (IMG:style_emoticons/default/agree.gif) 100%. Very pricey, which is why I don't own one & borrow my friends (IMG:style_emoticons/default/laugh.gif) . (IMG:style_emoticons/default/cool_shades.gif) |
0396 |
Jun 30 2007, 08:50 AM
ALL,
Thanks for the education. I guess the last factor that I WILL make is where to park it.. wife does not want it on the drive way. She points out and 'how' many days will you used this? Good advice on U Haul.. but after reading the artical last Sunday's LA Times regarding how bad some are maintain... Again, thanks for all the advice |
Lo-Fi Version | Time is now: 8th June 2024 - 10:03 AM |
