Exhaust Nut size, ....yeah, I said "nut size" 8*) |
jaybird840 |
Aug 6 2007, 04:51 PM
Member Group: Members Posts: 163 Joined: 27-September 06 From: Austin, TX Member No.: 6,927 Region Association: Southwest Region |
Missing a nut off of one of my exhaust studs. Thought I found it at my FLAPS but wouldn't fit when I got home.... What's the correct size? (IMG:style_emoticons/default/headbang.gif)
davep |
Aug 6 2007, 04:55 PM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Should be an M8. Better to get a proper nut for the application eventually. A standard nut will probably not last long.
McMark |
Aug 6 2007, 07:23 PM
M8, but most M8 nuts use a 13mm wrench. You need the M8 that uses a 12mm wrench. The larger ones will sometimes hit the tubing.
type47 |
Aug 6 2007, 08:10 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
isn't it a special copper nut?
URY914 |
Aug 6 2007, 08:30 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
SGB |
Aug 6 2007, 10:15 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
A vee- dub place should have 'em too.
Lo-Fi Version | Time is now: 9th June 2024 - 12:08 AM |
