looking for a picture of an engine bay heater set up, installing heat and the haynes manual sucks |
pba110 |
Aug 9 2007, 09:15 PM
Newbie Group: Members Posts: 47 Joined: 19-July 07 From: east coast Member No.: 7,921 |
anybody got some engine bay pics laying around?
i've got all these heating parts and i think i know where they go...but the haynes manual is less than desirable in it's description of its installation. i'm confused about the mounting of the blower motor...which hoses go where etc thanks in advance! pete |
pba110 |
Aug 9 2007, 09:41 PM
here are pics of the parts i have except for one off the elbows i have in the trunk...
on the car are the HE's and the heater flapper box cable. i've also got the flapper boxes...simple questions, but there are there blower motors in the front of the car? i've been told that there are and that there aren't any suggestions? oh this is going on a 74... where does the guide plate gO? thanks a lot guys! (IMG:http://i35.photobucket.com/albums/d189/pba110/914/IMG_1546.jpg) (IMG:http://i35.photobucket.com/albums/d189/pba110/914/IMG_1576.jpg) |
JC 914 |
Aug 10 2007, 09:56 AM
Member Group: Members Posts: 124 Joined: 21-June 07 From: Johnson City,TN Member No.: 7,827 |
Hey Pete,
Where on the east coast are you?? I've got pretty much the same situation!! Terry |
dr914@autoatlanta.com |
Aug 10 2007, 10:28 AM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
call me if you like and I will describe it to you 770 427 2844 ext 16
Dave_Darling |
Aug 10 2007, 10:55 AM
First pic: Those complex three-way things bolt onto the bottom of the fan shroud, the front of the heat exchangers, and the thirt part sticks up through the hole in the engine tin. The slightly bent pipe bolts onto the other front opening of the heat exchanger, and the "flapper box" clamps onto the front of it. (There should be two of those bent pipes, and two flapper boxes. I only see the one pipe and no flapper boxes.)
Second pic: The sheet-metal piece looks to be the one from a tail-shift car. It goes under the engine on the left side, bolting to the crankcase sump and the heat exchanger. The two paper hoses go from the flapper boxes to the holes in the body at the lower corners of the engine bay. The blower looks to be the 73-74 type, so it should get hose-clamped onto a stand welded onto the left-side engine shelf below the relay board. The single hose there goes from the heater blower outlet to the tube (the third pipe from the three-part things in the first pic) that sticks up through the engine tin. The right-side one would be capped off. I posted pics on how much of this fits together on the Bird board. Do a search on the 914 boar there for "flapper box" and you should find them. --DD |
914werke |
Aug 10 2007, 11:00 AM
"I got blisters on me fingers" Group: Members Posts: 10,140 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Dave are you suggesting that the flex hoses that connect the flap valves to the body as OE were the "PAPER" type and not the rubber with wire support more commanly found?
pba110 |
Aug 10 2007, 12:03 PM
awesome.
thanks for the help guys especially dave, you've really been helping me out, thanks this weekend, i'm trying to complete: -rotor/brake install on all four -alternator install (very, very scared of this one) -heating system -minor rust removal and inhibitor paint application wish me luck thanks for the info guys -oh i live in VA where are you on the EC? |
rhodyguy |
Aug 10 2007, 12:27 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the triangular tin piece lives above the rear shift rod in a sideshift config. the curved portion points up. it connects to the bottom of the case and the heat exchanger on the driver's side. it provides quit a bit of stability for the he and helps protect the bottom of the cyl and pushrod tubes. there should be a similar shaped piece on the pass side. it will have a squarish channel running thru lengthwise. it fastens in pretty much the same fashion
k |
terrymason |
Aug 10 2007, 01:07 PM
Member Group: Members Posts: 346 Joined: 23-November 05 From: Virginia Beach Member No.: 5,174 |
awesome. thanks for the help guys especially dave, you've really been helping me out, thanks this weekend, i'm trying to complete: -rotor/brake install on all four -alternator install (very, very scared of this one) -heating system -minor rust removal and inhibitor paint application wish me luck thanks for the info guys -oh i live in VA where are you on the EC? Where in VA? There are some of us scattered all around, with alot in northern va. On the brakes - the fronts are pretty easy / standard, but I've heard (haven't done it) that the rear brakes are fairly difficult, and some venting clearances have to be set. No first hand knowledge here, just rumor. |
swl |
Aug 10 2007, 02:07 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Engine Bay looking down from the drivers side.
Plumbing - driver's side from the rear. |
swl |
Aug 10 2007, 02:09 PM
Plumbing - from the front
JC 914 |
Aug 10 2007, 02:35 PM
awesome. thanks for the help guys especially dave, you've really been helping me out, thanks this weekend, i'm trying to complete: -rotor/brake install on all four -alternator install (very, very scared of this one) -heating system -minor rust removal and inhibitor paint application wish me luck thanks for the info guys -oh i live in VA where are you on the EC? N.E. tENNESSEE - Tri-cities area. Near Bristol Motor Speedway |
Dave_Darling |
Aug 10 2007, 08:14 PM
Dave are you suggesting that the flex hoses that connect the flap valves to the body as OE were the "PAPER" type and not the rubber with wire support more commanly found? Oh, crap--good catch!! No, I'm suggesting (now) that I don't know which hoses those are in the pic.... (IMG:style_emoticons/default/wink.gif) --DD |
JPB |
Aug 10 2007, 08:52 PM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
If its not done, bring it to the East Coast Cookout and you will have some help there. I will personally supervise the repairs while totally intoxicated on some home brew from our local Brewmeister Zymergist! If all else fails and your quasi conchious, you could always tow it back home. (IMG:style_emoticons/default/beer.gif)
Lo-Fi Version | Time is now: 8th June 2024 - 02:00 PM |
