firewall, will a 72 fire wall fit on my 73 |
martin914 |
Sep 1 2007, 01:11 PM
martin914 Group: Members Posts: 48 Joined: 23-October 05 From: beauharnois cdn Member No.: 4,987 |
hi everyone the firewall (behind the seat ) on my 73 is rusted out pretty bad i found a 72 firewall in perfect shape dont ask me why the rest of the car is rotten everywhere maybe because it does not have a engine side insulator anyway i want to know if it will fit thanks
hwgunner |
Sep 1 2007, 02:04 PM
914 Parts @ Discount Prices 800.321.5432 Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
It will fit. If you get down into the holes at the bottom though the holes on a 72 are a little different than the holes on the 73. I know for sure that the shift rod bushing at the firewall changed between the 72 and 73 model years. If you do use the bottom piece from the 72 they do make a "conversion" bushing to convert an early car to side shift and this conversion bushing would solve this one problem for you. Not sre about he rest of the penetrations for fuel, breaks, clutch accelerator wire harness etc.
martin914 |
Sep 2 2007, 11:49 AM
(IMG:style_emoticons/default/sawzall-smiley.gif)
It will fit. If you get down into the holes at the bottom though the holes on a 72 are a little different than the holes on the 73. I know for sure that the shift rod bushing at the firewall changed between the 72 and 73 model years. If you do use the bottom piece from the 72 they do make a "conversion" bushing to convert an early car to side shift and this conversion bushing would solve this one problem for you. Not sre about he rest of the penetrations for fuel, breaks, clutch accelerator wire harness etc. thanks jonathan i will use only the top part where it meets with the engine shelve |
Lo-Fi Version | Time is now: 31st May 2024 - 10:49 PM |
