QUOTE(hwgunner @ Sep 1 2007, 12:04 PM)
It will fit. If you get down into the holes at the bottom though the holes on a 72 are a little different than the holes on the 73. I know for sure that the shift rod bushing at the firewall changed between the 72 and 73 model years. If you do use the bottom piece from the 72 they do make a "conversion" bushing to convert an early car to side shift and this conversion bushing would solve this one problem for you. Not sre about he rest of the penetrations for fuel, breaks, clutch accelerator wire harness etc.
thanks jonathan i will use only the top part where it meets with the engine shelve
