Green lug bolts, What to do? |
orthobiz |
Sep 29 2007, 12:35 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I know the lug bolts are plated for the Fuchs wheels. Like a zinc plating or something.
Who does refinishing? Thanks. Paul (IMG:http://farm2.static.flickr.com/1117/1458436045_3bc343b850.jpg) (IMG:http://farm2.static.flickr.com/1340/1459300108_7ddfaba17d.jpg) (IMG:http://farm2.static.flickr.com/1418/1459297774_9f60e87f6b.jpg) |
dr914@autoatlanta.com |
Sep 29 2007, 12:45 PM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
any one who does cad plating can refinish them for you or you can just paint with silver wheel paint and install with a soft socket. Of course the factory used plastic lug nut covers to cover the heads so you could buy those.
I know the lug bolts are plated for the Fuchs wheels. Like a zinc plating or something. Who does refinishing? Thanks. Paul (IMG:http://farm2.static.flickr.com/1117/1458436045_3bc343b850.jpg) (IMG:http://farm2.static.flickr.com/1340/1459300108_7ddfaba17d.jpg) (IMG:http://farm2.static.flickr.com/1418/1459297774_9f60e87f6b.jpg) |
orthobiz |
Sep 29 2007, 12:49 PM
Thanks, Doc. Steve G bought these from you years ago!
Now, regarding the plastic covers: Did the "2.0 Fuchs" come with plastic covers? Is it appropriate in the CW circles to use the covers? Or is it simply a convenient solution? Paul |
davep |
Sep 29 2007, 01:30 PM
914 Historian Group: Benefactors Posts: 5,154 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
The green you see is the copper corrosion products. They plated the steel bolt with copper, then cadmium. Cad plating is not common anymore due to its toxic nature. You might consider silver zinc plating. A bunch of CW's might consider pooling their bolts for new cad plating if a plater could be found.
Lo-Fi Version | Time is now: 10th June 2024 - 10:51 PM |
