Any recommendations for tranny oil ?, I want to change my tranny oil, what should I use ? |
levonfarra |
Oct 1 2007, 12:37 AM
Member Group: Members Posts: 173 Joined: 10-February 07 From: Encino, CA Member No.: 7,521 Region Association: None |
sww914 |
Oct 1 2007, 01:42 AM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
Swepco 201. Don't use synthetic. Porsche trannys love Swepco.
levonfarra |
Oct 1 2007, 12:59 PM
How many gallons do I need? Sorry for the ignorance but I am at work and do not have my owners manual w/ me and I want to order it.
thanks, Levon |
So.Cal.914 |
Oct 1 2007, 01:09 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Transmission including differential Approx. 2.5 liters/2.6 U.S. gt of transmission
fluids meeting Specifications MIL-L-2105 B or MIL-L-2105, SAE 90 Viscosity (IMG:style_emoticons/default/smile.gif) |
Rand |
Oct 1 2007, 02:08 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
80w90 GL5 (NOT GL4) or Swepco 201
Cap'n Krusty |
Oct 1 2007, 02:57 PM
Why do you want to change the gear oil? The Cap'n
levonfarra |
Oct 1 2007, 03:29 PM
I have owned the car for about 7 months, but I am not sure when the last time the oil was changed, so I figured it's better to be safe than sorry.
Cap'n Krusty |
Oct 1 2007, 03:40 PM
Gear oil doesn't wear out. If it's the wrong oil, it won't shift right. If it's full, and shifts OK, and the tranny's not so noisy you want to look at the scrap metal stuck on the drain plug magnet, you needn't bother to change it. If you decide to do it anyway, be sure you remove the fill plug BEFORE you drain the oil. No sense draining it only to find you can't refill it! The Cap'n
levonfarra |
Oct 1 2007, 03:50 PM
Gear oil doesn't wear out. If it's the wrong oil, it won't shift right. If it's full, and shifts OK, and the tranny's not so noisy you want to look at the scrap metal stuck on the drain plug magnet, you needn't bother to change it. If you decide to do it anyway, be sure you remove the fill plug BEFORE you drain the oil. No sense draining it only to find you can't refill it! The Cap'n Most of the time it shifts good, however yesterday I went on a very curvey canyon road and twice I had a hard time downshifting into second gear, when the road straightened out the shifting was fine again. So I figured oil is low or old and either case it would be a good idea to change oil. |
rfuerst911sc |
Oct 1 2007, 06:09 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
Gear oil doesn't wear out. If it's the wrong oil, it won't shift right. If it's full, and shifts OK, and the tranny's not so noisy you want to look at the scrap metal stuck on the drain plug magnet, you needn't bother to change it. If you decide to do it anyway, be sure you remove the fill plug BEFORE you drain the oil. No sense draining it only to find you can't refill it! The Cap'n Most of the time it shifts good, however yesterday I went on a very curvey canyon road and twice I had a hard time downshifting into second gear, when the road straightened out the shifting was fine again. So I figured oil is low or old and either case it would be a good idea to change oil. This sounds more like worn engine/tranny mounts then gear oil. |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:00 AM |
