| pffft |
Oct 3 2007, 12:46 PM
Member ![]() ![]() Group: Members Posts: 189 Joined: 18-January 05 From: sierra foothills Member No.: 3,465 |
| TravisNeff |
Oct 3 2007, 01:19 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
Engmans kit does the same thing.
| andys |
Oct 3 2007, 02:33 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None
What I find attractive about this frame brace, is that it is a bolt-in solution, which avoids the pitfalls of a welded-in structure. Additionally unlike the popular 914 scab plate concept, this brace utilizes a formed structural shape for improved rigidity per unit weight. I think it's interesting, and spawns alternative design ideas.
Thanks for sharing, Andys |
| stateofidleness |
Oct 3 2007, 02:44 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
i, too, love the fact that it is bolt-in as opposed to weld-in
im trying hard to think how there could be a bolt-in solution for the 914 though... |
| pffft |
Oct 4 2007, 02:25 PM
It is the bolt in possibility that interests me most. There are formed chassis rails
and then cross pieces. I certainly don't have any way of producing something like this, but I would really consider using one if they were available. ![]() |
| PeeGreen 914 |
Oct 4 2007, 02:34 PM
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest
Yes, I think that would be very interesting, and no the Engman kit does not do the same thing. Plus, having it be something you can bolt on would be a cool addition.
| grantsfo |
Oct 4 2007, 02:43 PM
Arrrrhhhh! ![]() ![]() ![]() ![]() Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Part of what makes these so effective on the Miata is the structure is triangulating the transmission tunnel. On 914 it would just be reinforcing existing floor pan and probably be less effective. Still worth exploring however.
| TravisNeff |
Oct 4 2007, 03:27 PM
Yes, I think that would be very interesting, and no the Engman kit does not do the same thing. Plus, having it be something you can bolt on would be a cool addition. I disagree. The engman kits makes a box on the frame (well 3/4 of a box), true his kit does not make an X across the middle - but it attaches to the frame rail to box the section. Glorified subframe connectors if you like, it's been around for years. |
| URY914 |
Oct 4 2007, 05:13 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 131,656 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
The Miata brace creates a box section by enclosing the bottom of the tranny tunnel. It become somewhat like the old Lotus Elan which has a "backbone".
Adding an x-brace to the bottom of our cars will do very little. |
| brer |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
I had an idea once. Kinda like this, but using prestressed members laminated in carbon fiber that would run down the ouside of each long in the rocker area and wrap under the rear area as a subframe, while also attaching to the forward suspension mounts. It was just a thought though. Way beyond my experience.
| Katmanken |
Oct 4 2007, 07:34 PM
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Just make a tall tranny tunnel to mimic the Lotus backbone.
The Lotus also hangs the suspension from the backbone. Colin Chapman was a nut for minimalistic lightweight structures. Ken |
| PeeGreen 914 |
Oct 4 2007, 07:44 PM
Yes, I think that would be very interesting, and no the Engman kit does not do the same thing. Plus, having it be something you can bolt on would be a cool addition. I disagree. The engman kits makes a box on the frame (well 3/4 of a box), true his kit does not make an X across the middle - but it attaches to the frame rail to box the section. Glorified subframe connectors if you like, it's been around for years. Don't get me wrong Travis. I like the Engamn kit, and I am about to weld it in my car next month. The thing about this brace that has the strength is in the trianglation. As stated by others, it would be kinda pointless on the 914 as our car has a flat bottom already. Adding strength to ours like the engman kit will help to make our cars a little stiffer, but you have to weld it in as opposed to this bolt in application. |
| andys |
Oct 5 2007, 11:34 AM
There are some things about that Miata stiffener that perhaps doesn't suit the 914, but the product they call "FM frame rail reinforcement kit" http://www.flyinmiata.com/index.php?deptid...number=13-69010
may have some merit. Two bolt in longitudinal hat sections similar to these could greatly enhance stiffness with a bot-in scheme if configured properly. The Engman kit looks to solve many of these same issues in a different way. The lower firewall brace portion looks to help tie-in "the box". If there was a way to do something similar in the front (bulkhead) as well, then it seems that would help complete the structure. It's always interesting to look at alternative ideas. Andys |
| Air_Cooled_Nut |
Oct 5 2007, 12:20 PM
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
The Miata brace creates a box section by enclosing the bottom of the tranny tunnel. It become somewhat like the old Lotus Elan which has a "backbone". Adding an x-brace to the bottom of our cars will do very little. (IMG:style_emoticons/default/agree.gif) The 914 was designed as a sports car by one of THE sports car houses. We have an actual enclosed tunnel whereas the others have an opened-bottom tunnel so ours is naturally stiffer. |
Lo-Fi Version | Time is now: 13th March 2026 - 09:40 AM |
