sj914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 ![]() |
I suspected that the panel had rust so I took off the panel thats welded on the middle of the transmission mount hump in the rear trunk and found the below picture. Anyone know if this is still good enough to just clean up or would this be a good time to cut it out and replace the rusted section.
Attached image(s) ![]() |
sj914 |
another.
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Leave it. Lay a bead of weld all the way around the tranny ears so they have a little more than the 3-4 spot welds that hold them to that cross member.
B |
Carrera916 |
Member ![]() ![]() Group: Members Posts: 292 Joined: 9-February 03 From: Pleasanton, CA Member No.: 273 ![]() |
Yeah....but while it's already opened, wire brush it real good, clean it out with Prep70 or wax/crud remove solvent and use good quality epoxy primer like the PPG DP(#), depending on what color primer you want. Before you spray paint it, mask off the area as small as you can where you want to spot weld the piece back on. DP primers really handle the heat very well based on my experiences.
Another option is that you could weld it back on and use a special spray gun that has a long flex hose with nozzle at the end where you could stick the nozzle into the hole of the gearbox crossmemeber. Push the nozzle far inside till it reach the other end of the crossmemeber then pull the trigger to spray from one end to another by pulling out the hose out slowly.....don't forget to let go the trigger when you get close to the hole you started at otherwise you'll be primered and rust free for rest of your life! Some people would use POR 15....jeez, that shit is something and I do have mix feelings about it....the result looks good and I have had some cars come back after about a year or so with slight bubbles....aaarrrr! Have you tried remove old POR 15?...FUN FUN FUN j |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
spray everything with metal ready, you can weld through the metal ready once it's dry. that'll keep it from rusting ...
Andy |
sj914 |
Thanks guys. My plans were to actually strip the whole trunk and spray por15. The way it looks in the pics is after using a wire brush on the angle grinder. I'll try to go at it with the wire brush again.
Lo-Fi Version | Time is now: 17th June 2024 - 11:12 AM |
