| Wilhelm |
Oct 16 2007, 06:15 PM
Member ![]() ![]() Group: Members Posts: 408 Joined: 7-September 07 From: Hooterville, OR Member No.: 8,088 Region Association: None |
Does anyone have any experiance with electrolytic rust removal? I've done this with smaller parts in a tupperware pan with good results, but wonder if anyone has tried doing their whole car. I could easily fit the entire car in a 15 x 3 foot kiddie pool. The hardest part as far as I can see would be drying the vehicle off fast enough to avoid flash rust. A 15 foot pool would require about 15 gallons of washing soda ($30.00). Here are some links: http://www.stovebolt.com/techtips/rust/ele...c_derusting.htm and http://www.metacafe.com/watch/456478/rust_removal_tip/
| TedK |
Oct 16 2007, 08:40 PM
Member ![]() ![]() Group: Members Posts: 163 Joined: 1-August 07 From: Thousand Oaks, CA Member No.: 7,961 |
Interesting. How do you clean the black metal for priming when finished?
| okieflyr |
Oct 16 2007, 08:59 PM
9fauxteen ![]() ![]() ![]() Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
Hmmmmm, a hoist, a neighbors swimming pool while they are gone for the weekend, and you can have a clean tub!
| Wilhelm |
Oct 17 2007, 12:20 AM
Interesting. How do you clean the black metal for priming when finished? The black crud wipes off fairly easily, sometimes takes a little steel wool, but not much elbow grease. It sometimes shocking to see how much rust was really there. The good news, is that non-rusted metal doesn't dissappear. The difficult question I think is re-protection of areas you can't see and can't readily access like inside the longs. Do any of you do anything to protect inside these enclosed areas in any way? Have to wonder if you could thread a weed sprayer into some of these areas, set it on mist and coat those difficult to reach areas with one of those glasser ionomer paints or zinc type paints? Heck, as long as its in the neighbor's swimming pool (IMG:style_emoticons/default/w00t.gif) , I may as reverse the anode/cathode and galvanize it up a bit. |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:51 PM |
