driver side rear wheel is hard to rotate |
buck toenges |
Oct 28 2007, 08:23 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
I have a rear wheel that doesn't spin as easily as the other rear wheel. When I jack up the car I can hand turn the passenger side wheel very easily when the tranny is disengaged but the driver side is very "stiff" I assume it is either the caliper not adjusted properly to the rotor or a bad hub bearing. How and what can I do to find out the problem?
Thanks, Buck |
davep |
Oct 29 2007, 08:44 AM
914 Historian Group: Benefactors Posts: 5,154 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Remove the pads or the caliper to determine if the brakes are dragging. Check the adjusters to see if the pistons can adjuster easily. If they don't then you should rebuild the rear calipers as a set. Call Eric on this. You could even have a bad brake flex line (rubber) that is acting as a one way valve. Or the parking brake cable might be stuck and keeping the brake from releasing.
If you still have a problem without the brake in place, you could separate the axle from the tranny to isolate the problem. Normally the CV joints don't bind, so you could wobble the CV's and check for free motion. Then rotate the shaft and see if the bearing is stiff. If none of that seems to be the problem, then you are getting into the tranny and the Diff bearings. |
McMark |
Oct 29 2007, 12:13 PM
My vote: time for rebuilt rear calipers.
But (IMG:style_emoticons/default/agree.gif) 100% with Dave. |
Lo-Fi Version | Time is now: 9th June 2024 - 08:31 PM |
