Hooking up the Crane xr700 optical ign., need some help |
JBart |
Nov 14 2007, 11:08 PM
UNDER CONSTRUTION Group: Members Posts: 110 Joined: 9-October 06 From: Wildomar Ca. Member No.: 7,019 |
Looking for some help installing the Crane xr700 into a 019 dizzy . Does anybody have pics. of one installed looking in the dizzy so I can see which brackets and shutter to use ? The directions suck or I can't read . ( It might be me)
Thanks, jbart |
Van914 |
Nov 15 2007, 04:21 AM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
The shutter is easy do you have a 4 or a 6? Two brackets are used. The trick is to get the sensor positioned under the cap. Not too hard. I used the small bracket on the dist plate and the long slider on the sensor. The shutter has to be installed with the sensor at the same time.
Mine worked like a charm for 8 years, until I went to a 3.0 six. Van |
blitZ |
Nov 15 2007, 06:27 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I also have the Crane, which works great, but setup is a bit tedious. It's easier if you pull the distributor. Once you get the bracket on leave the slider loose, you'll need to be able to move it during the final configuration. IIRC, I had a hard time getting the wheel on the shaft and had to trim a little material out of the inner corners.
Van914 |
Nov 15 2007, 07:27 AM
To get the wheel omn the shaft I used the rotor to push it on.
van914 |
Lo-Fi Version | Time is now: 7th June 2024 - 09:41 PM |
