Induction parts, Searched, but triptophan in effect |
Pat Garvey |
Nov 22 2007, 08:41 PM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
I can't remeber where this was originally posted ("guess this Part"?), but the turkey made me take a shortcut.
This was the orignal part discussed..... Was discussed that this might have been a domestic part rettofitted to a spare air cleaner ('72) housing I have. Still don't know what it does & isn't listed in PET, but see the following...... Pat Attached image(s) |
GWN7 |
Nov 22 2007, 08:46 PM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
Lots of stuff not listed in PET but it does exist (IMG:style_emoticons/default/smile.gif)
AC (now AC Delco) stuff is found on lots of cars |
Pat Garvey |
Nov 22 2007, 08:53 PM
Now, this is my original (also a 72) & I still don't know what it does.
You can see in the pic that is missing a "leg" - could've happened anytime over the last 30 years, but it it completely different. PN (VW) 022129640 - what's it's purpose? Also included in the pics is the scewdown bolt for my '72 - soldered wingnut variety. Pat Sorry - I know this is crossposted, but the Thanksgiving turkey (wild) left me with enough triptophan that I'm getting verry sleepy & don't give a sh_t. Attached image(s) |
Slider |
Dec 12 2007, 12:19 AM
Problems are like cockroaches you find 1 and theres a 100 more Group: Members Posts: 223 Joined: 11-March 07 From: Fort Collins Colorado Member No.: 7,591 Region Association: Rocky Mountains |
My 72 has the same piece on the air cleaner. so i dont think it was only that one mine is a CA car and it had it. with the AC on the top and everything.
im under the assumption it is a temperature controlled vaccum valve. mine has the two ports and one side goes to the intake manifold and the other side goes to the Vaccum operated valve that opens and closes between pulling in air from the top air horn and the bottom one that is ducted under the motor. thats my take..maybe its just mine.. but hope it helps.. #5 on the diagram is my AC branded valve (IMG:http://togobeyond.net/914/01-1_4.jpg) |
Pat Garvey |
Dec 12 2007, 07:21 PM
My 72 has the same piece on the air cleaner. so i dont think it was only that one mine is a CA car and it had it. with the AC on the top and everything. im under the assumption it is a temperature controlled vaccum valve. mine has the two ports and one side goes to the intake manifold and the other side goes to the Vaccum operated valve that opens and closes between pulling in air from the top air horn and the bottom one that is ducted under the motor. thats my take..maybe its just mine.. but hope it helps.. #5 on the diagram is my AC branded valve (IMG:http://togobeyond.net/914/01-1_4.jpg) Your diagram helps a lot & I believe it's spot on. Now it's starting to make some sense! Thanks! But......question is - can this part be replaced, because I broke one of the vac legs removing mine? I mean I know how to replace it, but are replacement parts available? Pat |
Lo-Fi Version | Time is now: 23rd May 2024 - 08:21 AM |
